1913 body braces
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
1913 body braces
Post by RichJ » Thu Jan 20, 2022 8:11 am
About a week ago there was a thread , in which Hap Tucker posted info on the reinforcing brackets that were necessary
for the weak design on some 1913 bodys
viewtopic.php?f=2&t=26387
I would like to see the information that wold picture the brackets.possibly someone can find this in the archives and post
Thanks Rich
RichJ
First Name: Rich
Last Name: Jesteadt
Re: 1913 body braces
Post by RichJ » Thu Jan 20, 2022 8:17 am
wrong link
I hope my mechanical skills are better than my computer skills
RichJ
First Name: Rich
Last Name: Jesteadt
Post by RichJ » Thu Jan 20, 2022 8:23 am
The info was from letter number 395 and it referenced T5434 and sketch T5638
Post by DanTreace » Thu Jan 20, 2022 9:14 am
Don't have copy of those part #s, but Bruce's C-D Ency. (another reason to buy this $50 super C-D) has picture of the frame bracket and the reinforcement body bracket installed on a body. And attached is copy of Ford instructions for install.
Early 1913 body bracket and frame bracket.jpeg (101.67 KiB) Viewed 5707 times
Post by RajoRacer » Thu Jan 20, 2022 10:29 am
I have a '13 Touring in the shop currently with those rear support brackets & the owner has access to a very substantial machine & fabrication shop and is considering doing a limited run of these if there's interest.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Thu Jan 20, 2022 10:45 am
1913. A year to remember.
"Get a horse !"
Sarikatime
Last Name: Seress
Post by Sarikatime » Thu Jan 20, 2022 12:21 pm
Someone is selling a set of support brackets on this website on parts.
Post by Rich Eagle » Thu Jan 20, 2022 4:59 pm
I sold these a few years ago. This shows common wear and abuse and possibly some detail.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Thu Jan 20, 2022 6:06 pm
I need a pair. There are two widths of sills if I remember correctly.
RichJ
First Name: Rich
Last Name: Jesteadt
Post by RichJ » Thu Jan 20, 2022 6:50 pm
Here is the information that I was referring to this morning:
JAN 28 1913 Acc. 575, Letter 395, Ford Archives
T-5637 Body Reinforcing Bracket Bolt. "Four required, Touring Car, 1913."
T-5453 Body Reinforcing Bracket. New Drawing. "Two required, Touring Car, 1913."
T-5638. Sketch showing location of Body Reinforcing Bracket. "We have made this sketch for the purpose of showing customers who are having trouble with the touring car bodies how the trouble can be overcome. The material has been ordered and we will be able to supply same in the near future. For your information will state that the construction of the body has been improved upon and undoubtedly will not need this reinforcement as soon at the change can be brought about. We will therefore order only enough material of the above parts as shown on sketch to take care of the bodies which have already been built."
Post by Scott_Conger » Thu Jan 20, 2022 10:17 pm
FWIW, My Jan 2, '13 car sports a set of these, and I believe them to be original to the car
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Thu Jan 20, 2022 10:35 pm
Scott, The "Ford Sales Bulletin", dated May 1913 states that these braces are now available to dealers. My January 1913 touring has the frame brackets that are bolted to the frame. There is no doubt that Ford knew there was a problem with the weakness of the sills and these braces were retrofitted to earlier (pre-May 1913) cars. I hope this helps. Russ Furstnow
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Fri Jan 21, 2022 1:00 am
January 1913 touring.
gtttrobinson
First Name: Gerald
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T Touring + 1923 Model T Touring
Post by gtttrobinson » Tue Jan 25, 2022 11:55 pm
Could I join the list for two sets? Have you put out a call for those interested?
Thank you btw!!
Post by RajoRacer » Wed Jan 26, 2022 10:02 am
The fella is coming to the shop today - I'll ask him about producing some.
gtttrobinson
First Name: Gerald
Last Name: Robinson
Post by gtttrobinson » Wed Jan 26, 2022 10:05 pm
Hi Rajo, if you strike out with you guy, I have a person I can speak to. I'd need a template and then a list of who wants them with sill measurements for each. Let me know what you think.
gtttrobinson
First Name: Gerald
Last Name: Robinson
Post by gtttrobinson » Wed Feb 02, 2022 9:57 pm
Hi RajoRacer,
Did you ever have luck with making up some braces? If so, I can be reached at gefrobinson@yahoo.com
Post by RajoRacer » Thu Feb 03, 2022 10:36 am
Fella's picking up the T on Monday and said he's going to make patterns after he gets it back to his shop - he's not one to drag his feet on a project - I'll attempt to stay on top of it.
Post by RajoRacer » Sat Feb 19, 2022 6:30 pm
My friend has removed a support bracket and is currently making patterns - if anyone might be interested, let me know. I have no idea on production costs as of yet but he mentioned having a dozen sets made up..
Model T Mark
Last Name: Eyre
Post by Model T Mark » Sat Feb 19, 2022 7:13 pm
I would be interested in a set I think.
Mark Eyre meyre14t@yahoo.com
jmc
Last Name: Carter
* REQUIRED* Type and Year of Model Ts owned: 1913, 1919, 1924
Post by jmc » Tue Feb 22, 2022 8:43 am
I would be interested.
John
Post by RajoRacer » Tue Feb 22, 2022 10:29 am
He's coming out today to retrieve his other chassis I got running for him - I'll check on the brackets progress !
