1909 Running boards
1909 Running boards
Post by Dollisdad » Fri Mar 04, 2022 12:07 pm
I am going to produce Model T boards this spring. It will be the last time I do this. I am wondering if there is any need to run the 1909 boards. So speak up——or forever hold your peace.
Tim Rogers
Last Name: Rogers
Re: 1909 Running boards
Post by Tim Rogers » Fri Mar 04, 2022 12:28 pm
Tom- are you going to be scaling back on other production as well?
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Fri Mar 04, 2022 12:40 pm
If he does not reproduce the 09 boards or you do not want to wait, I have a nice pair for sale.
Post by Wayne Sheldon » Fri Mar 04, 2022 5:51 pm
Just a question, clarification? 1909 running boards were unique, and not stamped steel. They were if I recall correctly, wood, covered with linoleum, and trimmed with metal edging that is easily made. Late in 1909 calendar year, generally considered 1910 model year, the stamped steel running boards were introduced with the multiple long broken stamped lines.
I would guess that those are the running boards you are referring to?
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Fri Mar 04, 2022 6:12 pm
Only the first run of the 1909 model year Ts were of wood. The rest of the 1909 model year had steel running boards with long ridges.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Tue Mar 15, 2022 4:37 pm
I have an original 1909 pair at $300 plus the ride.
Michael A
First Name: Michael
Last Name: Abbott
* REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
Post by Michael A » Tue Mar 15, 2022 6:00 pm
Hi Tom, any updates on the early fuel tanks, correct me if I’m wrong, I herd you were looking into making them.
Thanks Michael
Post by Original Smith » Wed Mar 16, 2022 9:08 am
Take into consideration the so called 1913-25 running boards. The only thing that is the same on them is the direction the Ford script goes. A lot of other things are different if you wish to have an authentic car.
Post by Original Smith » Thu Mar 17, 2022 11:08 am
Tom: Why not consider making the other style 1913 front fenders with the lip sticking out like a 1912, but even all the way around?
