Tell me about head gaskets
Last Name: Juhl
Post by Oldav8tor » Mon Mar 07, 2022 6:10 pm
I've never been able to inspect a copper head gasket closely. Are they one piece of copper or a sandwich of copper and other materials? If one-piece I would think that they could be cut with a laser or other cutting technology.
I heard the shortage is because the die used to make the gaskets was damaged. Anybody know the details?
Dropacent
Last Name: Morsher
Re: Tell me about head gaskets
Post by Dropacent » Mon Mar 07, 2022 6:26 pm
Blows my mind someone isn’t wacking them out, Tim. It ain’t rocket science. The days of the $35 head gasket are gone, though.
Post by TXGOAT2 » Mon Mar 07, 2022 6:54 pm
Most "copper" head gaskets are a sandwich of soft sheets of copper with a filler of some type of heat-resistant fiber. The openings around the cylinder bores and many of the water passages are ringed with sheet copper channel. Many gaskets come with a coating of varnish like material, and some are bare. As early as 1949, Ford was using head and intake manifold gaskets made of asbestos fiber over a sheet steel perforated core and impregnated with graphite. Annealed steel channel was used around most openings.
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Mon Mar 07, 2022 7:33 pm
I would add that some of the modern Model T copper clad gaskets contained an elastomer material much like
a 350 chevy head gasket.
The last run of these I had made up used the original Fitzgerald dies. I did so after experiencing head gasket
failures (others here did as well) when they replaced the asbestos with a fiberglass type material. I had to
do a minimum run of 100 gaskets. Most were sold to local T guys here at cost ($20).
I am currently out of the country so can't check the manufacturers name.
Harry Lillo
Panama
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Mar 08, 2022 9:43 am
Let’s get with the program, Harry ! Vacation over
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Tue Mar 08, 2022 10:09 am
Tim,
My wife says I have to stay here little a longer!!
Harry
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Tue Mar 08, 2022 11:35 am
Tim, if you want to take a close look at a copper head gasket, I have two; one that was kinked a little on removal before I knew they were now unobtainable, and another that may be reusable. I have about 50-60 miles on a silicone head gasket and so far so good, but it hasn’t been run very hard. My other T is currently headless and I haven’t 100% made up my mind whether to use a new silicone gasket or the used copper one.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Post by TXGOAT2 » Tue Mar 08, 2022 12:02 pm
You might try soaking the old gasket in soapy water, then rinsing it off and freezing solid it while it's still wet. Thaw it out and dry it thoroughly before coating with Coppercoat and using.
Post by Steve Jelf » Tue Mar 08, 2022 12:04 pm
When Adam Doleshal finished my engine work he used one of these to put the head back on. He says they're excellent, and he uses them instead of copper.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Tue Mar 08, 2022 1:07 pm
"Gaskets - To - Go" will make you a head gasket.
https://gasketstogo.com/
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Tue Mar 08, 2022 1:12 pm
Steve, I can't find a website for that company. Do you have contact info?
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Tue Mar 08, 2022 3:35 pm
I assume this process is to re-expand the fiber layer?
Miles
Post by TXGOAT2 » Tue Mar 08, 2022 3:39 pm
Exactly. Baking in a 250 F oven and quenching in water might do the same thing, but it would probably ruin the oven. I haven't tried either process, but it's probably worth a try.
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Tue Mar 08, 2022 5:32 pm
I have soaked rare European motorcycle head gaskets in water and heated them with a propane torch to
swell the asbestos core and aneal the copper jacket.
With copper coat they have held with some fairly high compression ratios.
Also did so on an early Chevy once when one was not readily available.
You could probably do the same in an oven as Pat suggests. I would soak it first however.
Harry
Post by Steve Jelf » Tue Mar 08, 2022 11:04 pm
I bought a couple from Adam. You can contact him through the forum. Go to the top of this page and click on Extra Quick links, then Search for members.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Mar 09, 2022 8:16 am
If no one buys even the Felpro head gasket engine kits at $150.00, in no time they will quit production. Supply vs demand. Welcome to the death of a hobby. If you think this is high.., with oil prices going up, everything goes up!
Post by Scott_Conger » Wed Mar 09, 2022 11:09 am
Perhaps this will make the "my engine was running a little rough, so I took the head off" crowd think twice before they actually do it...
then again...
Post by Jerry VanOoteghem » Wed Mar 09, 2022 12:03 pm
I received the following message from Gaskets-To-Go...
Thank you for contacting me
We make that kind of gasket all the time, but I have not had any orders for model T gaskets. I suspect that might be because there have been large stocks of those NOS and aftermarket. If you can send me an image or drawing of any gasket and let me know the L x W x thickness and quantity I will be happy to let you know pricing
Regards,
John
Mark Anderson
Last Name: Anderson
Post by Mark Anderson » Wed Mar 09, 2022 2:41 pm
Olson's Gaskets: Engine Gaskets for the Antique Market
https://www.olsonsgaskets.com
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Mar 09, 2022 2:59 pm
They do not list the standard Model T head gasket.
Mark Anderson
Last Name: Anderson
Post by Mark Anderson » Wed Mar 09, 2022 3:09 pm
If you would send an old one for a pattern they will make it. Give them a call.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Mar 09, 2022 3:22 pm
I have purchased several of Adam's gaskets and they work fine!
Last Name: Juhl
Post by Oldav8tor » Wed Mar 09, 2022 8:20 pm
I like this....looking for a solution is the Model T way!
