Riley Multi-Lift Valve Actuators
DanHayes
Last Name: Hayes
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster PU & 27 Touring
Post by DanHayes » Fri Apr 05, 2019 9:45 pm
Anybody have any idea how much these Riley Multi-Lifts are worth? I have a full set with valves, springs, lifters etc. that I pulled out of a members '16 engine. Her deceased husband had installed them in an engine that ran but was switched out for another engine but not sure why. As we disassembled the engine it seems to be in working order. They look to be in great condition. Any thoughts on pricing would be helpful as we will probably not use them in the engine we are putting back together. Thanks
Re: Riley Multi-Lift Valve Actuators
Post by Scott_Conger » Fri Apr 05, 2019 10:11 pm
When you do sell them, you can have the buyer reference this: http://www.mtfca.com/discus/messages/118802/125787.html
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Apr 06, 2019 6:08 pm
Dan:
sent an email … am interested , let me know if you decide to sell ...always an optimist...Gene French
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Apr 06, 2019 7:29 pm
IF I was able to buy these I would replicate them for those interested. Using 21 century technologies
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Sat Apr 06, 2019 10:20 pm
I almost sent you an email when I saw them Les, I should have, I knew you were looking for a set. Sorry
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Apr 08, 2019 10:03 am
Les:
reproducing the multi-lift would be my intent also … while these are not for everyone , they did effect a substantial performance increase even with the somewhat short life span … improved materials and heat treat process and some of the modern " dry-lube" coatings would probably increase the lifespan to a more tolerable range ...always an optimist...Gene French
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 08, 2019 10:46 am
Gene
No problem. I hope you get them. If you want to “commiserate “ about materials and process, please feel free to contact me!!
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Mon Apr 08, 2019 11:18 am
A couple of years ago I saw a set for sale at the Big 3 swap meet in San Diego. I believe the seller was from Arizona. He wanted $200 for the set. I thought about it but was concerned about the short life, estimated to be less than 10,000 miles according to the literature.
Tony Bowker
La Mesa, California
tdumas
First Name: Ted
Last Name: Dumas
* REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Post by tdumas » Mon Apr 08, 2019 12:31 pm
I suspect these were made by Jerry Hunt.
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Mon Apr 08, 2019 4:27 pm
Why are they so short lived, just a general lack of oil up to them or something else?
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Post by AandTman » Mon Apr 08, 2019 8:08 pm
Tony, that was me who had the Multi-lifts at SD. I do not remember quoting a price, as I was more interested in talking with those who might have some experience with them. I also had them out at Chickasha in 2018 and I believe I talked to Les about Reverse Engineering the concept. I have to admit not much done on that project as of this date.
Don Vagasky
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 08, 2019 8:38 pm
Not having ever actually touched a set of them, I could only guess at things related to wear,and I prefer NOT to guess about stuff like that
AandTman
First Name: Donald
Last Name: Vagasky
Post by AandTman » Mon Apr 08, 2019 9:58 pm
If it was not you whom I spoke with at Chickasha, it was somebody else from Canada,..... me assuming it was you.
Oh well mistaken identity...….
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Apr 08, 2019 11:08 pm
Les:
if I do get a set I would be glad to share the details … I have done a layout and milled a sample set of involute lifter levers from aluminum for test purpose … works well with regards to amplifying the lift … would have to be machined ( possibly wire EDM ) and heattreated to achieve any life span … is doable … not for everyone , for sure … I also considered machining a milder lift ratio … right now I have WAY too much to do … am finally finishing my home building project … always an optimist...Gene French
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Apr 09, 2019 9:31 am
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 09, 2019 2:56 pm
I suspect that “a positive spray “ oiling system in the valve chamber would make a significant effect on the life of these. IF the engine was pressure oiled it wouldn’t be too difficult and I wouldn’t be surprised if most installations on speedster engines might have a pressure system.
Possibly spraying for “relief valve flow” could do the job. Just a idea I’m kicking around!!
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Post by D.Yoder » Tue Apr 09, 2019 5:17 pm
This is what I have
This is what I have
John Warren
Last Name: Warren
Post by John Warren » Tue Apr 09, 2019 9:57 pm
These are very interesting, has anyone had these on a dyno? I did see the previously discussion. Thanks. sounds like there is some brilliant minds at work on re-producing these. I sure with some flow studies, an optimum lift can be discovered. I have been told that two much lift will start decreasing flow efficiency.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 09, 2019 10:14 pm
It seems that I have now acquired a set to evaluate. It should be fun!!
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Apr 09, 2019 11:10 pm
Glad you got them Les, Im waiting patiently for a set of "new and improved repros" . are they done yet .... :) :)
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Wed Apr 10, 2019 11:39 am
Les:
would be good to hear a detailed report on the performance of the multi-lifts... always an optimist...Gene French
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 10, 2019 12:36 pm
Gene
First I’m going to carefully evaluate the characteristics of the material. Try to determine what it is made of and it’s potential wear properties. Then I have a couple of possible engines to install it in AFTER I make 3D digital drawings of the components. A friend has a dyno so it might get tested for performance
DanHayes
Last Name: Hayes
Post by DanHayes » Sat Apr 13, 2019 10:44 am
To All,
Thank you for all the posts and information. One of the responses provided an estimate for what they were worth and it was in the range local enthusiasts had recommended I ask for them. I offered it to that individual so sorry for the many of you that were interested in them. I did not know they would be in such demand; probably should have put them on ebay and let the bidding begin, but I hate that process. As I mentioned I was selling these for a club member and she was very pleased with getting them to someone who would enjoy them as well as the money. Again thanks, Dan
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Apr 19, 2019 11:08 am
I have received the multi-lifts. Thank you Dean Yoder, a true gentleman!!
I have now had several conversations with Harry Lillo, the only person I know that has had extensive operation experience with them.
Yesterday I did some research and have now concluded that the “cams” are investment cast and heat treated 4140.
Studying the pictures of the originals, I believe that they had a a “locating ring” that coencided with the lifter boss, that is missing on the reproduction ones. I believe this may be the root cause of some operational issues that have been experienced
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Post by John bevardos » Fri Apr 19, 2019 11:38 am
Ok Les,
put me on the waiting list !
john
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Apr 19, 2019 1:59 pm
John
Don’t hold your breath!! First I want to resolve a couple of installation/operational concerns.
One (as I have mentioned) is “locking “ the device to the lifter bosses.
Another I want to explore is installing “valve rotators “ to help manage wear.
This is all going to take time!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Apr 20, 2019 11:56 am
So I am considering the idea of just using the Multi Lift concept on the intake valves. I believe that the reduction in performance would be very little and it would cut the installation issues in half!!
John Warren
Last Name: Warren
Post by John Warren » Sat Apr 20, 2019 9:19 pm
Interesting idea Les, It would be like installing a bigger intake valve:)
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Apr 20, 2019 9:51 pm
You guys know where Les will be for awhile! LOL.
Les, take breaks, great minds need a rest now and then.
All the Best,
Hank
Tom_Carnegie
Last Name: Carnegie
Post by Tom_Carnegie » Sat Apr 20, 2019 10:45 pm
I think just putting one on the intake might be a mistake. I'm sure that there would be some performance improvement, but I think there would be more with one on both the intake and exhaust. There is two aspects of the multi-lift: One is higher lift, the other is faster lift. There is a point of diminishing returns on higher life, not so with faster lift. I think the faster lift on the exhaust would help performance a lot, depending on the cam grind used.
