1926 window shades ???
Larry e rutt
Last Name: Rutt
* REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Post by Larry e rutt » Sat Mar 19, 2022 8:10 pm
So I am redoing the window shade material in my 26 fordor.. The bottom of the shade it has a wooden rod,at the end of the rod is a (eye hook). What is the eye for ??
Larry e rutt
Last Name: Rutt
Re: 1026 window shades ???
Post by Larry e rutt » Sat Mar 19, 2022 8:12 pm
1926 fordor
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sat Mar 19, 2022 8:16 pm
There are vertical guide strings tacked to the upholstery panels that keep the shade close to the window
Tom Miller
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Sat Mar 19, 2022 9:41 pm
Oh.. thanks. Anybody have any pictures ? My strings didn't survive.
Larry e rutt
Last Name: Rutt
Re: 1926 window shades ???
Post by Larry e rutt » Mon Apr 25, 2022 2:50 pm
I don't want to be demanding... anybody have details of where the strings attach, pics would be great thanks.
Post by Rich Eagle » Mon Apr 25, 2022 3:39 pm
I assumed this was correct when I did my '25 Tudor.
If I'm wrong someone will correct me.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Mon Apr 25, 2022 5:44 pm
Nice.... Thanks Rich.... I can do that.
Last Name: Patrick
Post by jiminbartow » Mon Apr 25, 2022 10:36 pm
Rich. Can you post a closeup of that fastener? Does it screw into the upholstery panel? Here is a photo of the shade of my ‘26 coupe. The shade has the cord on each lower corner, but I never could figure what it attached to. Thank you. Jim Patrick.
PS. Someone said the cord was to keep the shade close to the window, but I don’t think that is right because the cord is loose when the shade is pulled down. I think it is a shade arrester to prevent the shade from retracting too high if it suddenly released. The only way it could hold the shade down and the cord tight is if a boat cleat was used on each side to wrap the cord around, but I prefer the fasteners Rich used that make the cords into a shade arrester.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Mon May 02, 2022 8:45 pm
ah ha . I found what is left of my strings. behind the back seat at the rear window, and attached underneath the panel at the sides.
