I need any detail for a Model T door window lift actuator . I am trying find a work-around for a 1925 Essex that has a worm drive window lift actuator in a die cast or pot metal housing that has crumbled. I was told that a Model T ( do not know what year ) may have a similar lift actuator that might be adapted to the Essex. Any help or suggestions will be greatly appreciated.
Door Window lift
Bill Johnson
Topic author - Posts: 8
- First Name: Bill
- Last Name: Johnson
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 Roadster, 1927 Fordor, 1914 Touring project
Re: Door Window lift
This may narrow it down - or exclude some.
Also check out this PDF for 1925 Essex http://hudsonterraplane.com/tech/1925/1 ... thru25.pdf --Model T
- Attachments
- lift act 2.png (251.55 KiB) Viewed 1671 times
Bill Johnson
- First Name: Bill
Thank you for the pictures . I will try to locate one of the T risers to see if I can adapt it.
Thanks again
Thanks again
The only T window riser that’s available from the vendors is the riser for the 26-27 T closed cars. It’s the only T riser that is being reproduced and the others are hard to find if you can even find one. Go to Lang’s T Ford parts and you can get a good look at one to see if it can work for you. Good luck!
Bill Johnson
- First Name: Bill
Thank you for the tip.
Bill
Bill
