T Coupe Window Wood
daveclause
First Name: D
Last Name: R
Board Member Since: 2004
T Coupe Window Wood
Post by daveclause » Sat Feb 19, 2022 3:38 pm
What is a good source for the quarter and rear window wood trim on a 1927 Model T Coupe?
I looked at Howell's, Mac's, Lang's, and searched the internet. Mac's wants way too much money for their trim.
I don't have the tools to make my own in my garage so I can't do that.
I thought about just using wood pieces but not sure about that.
Re: T Coupe Window Wood
Post by John kuehn » Sat Feb 19, 2022 4:51 pm
Try Ford wood. They may be slow but give it a try. https://fordwood.com/images/cpe26new.jpg
Post by John kuehn » Sat Feb 19, 2022 7:22 pm
Here’s another Model T wood source https://www.classicwoodproductsllc.com/
daveclause
First Name: D
Last Name: R
Post by daveclause » Sat Feb 19, 2022 7:32 pm
Good info. Thanks! After looking for Fordwood, I also found Classic Wood Products.
Now the sites are jumping out at me.
I never heard of these businesses. Glad you told me.
daveclause
First Name: D
Last Name: R
Post by daveclause » Mon Feb 21, 2022 9:41 pm
Wow! The cost of the window wood is out of this world. $360, $254, and so on.
I might as well fab my own.
Anyone have the dimensions for the 27 Coupe quarter windows and rear window wood?
MHSprecher
First Name: Milford
Last Name: Sprecher
* REQUIRED* Type and Year of Model Ts owned: 1924 Coupe, 1910 Touring
Post by MHSprecher » Wed Feb 23, 2022 1:37 am
How close is it to 24-25 wood? Plans exist for the 24-25 wood.
jab35
Last Name: Bartsch
Post by jab35 » Wed Feb 23, 2022 10:45 am
Dave: I have measurements and some photos of the wood I fitted for the rear window of my '26 coupe. No side wood in mine. If you want to discuss, send an e-mail to jab35atcornelldotedu. I think you will at least need a band saw to cut those pieces. I'm glad to brainstorm with you if you like. jb
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Wed Feb 23, 2022 11:25 am
There are two threads with the same question...
On your other post, I show two different window styles.
Please tell/show us which one you have.
Ignore the 2x4 poking through the window.
The lower piece of wood is:
1-3/4" square at the B-pillar,
13-1/2" long,
5" tall towards the rear,
1-1/4" at the top, from front to rear,
The B-pillar 1-3/4" tapers to 1-1/8" at the rear.
The back side of the block to the rear is cut out for the #2 piece of wood.
View of the curve that follows the window steel.
1926 Coupe window 4.jpg (48.23 KiB) Viewed 3854 times
The bottom 6" of piece #2 has a slight taper on the back side.
A- 3/4"
B- 1-7/16"
C- 2-5/16"
D- 8-9/16"
E- 9-7/16"
F- 15-1/8"
G- 16"
H- 16-11/16"
I- hole 18"
J- hole 20-3/8"
K- 21-1/2"
1-1/16" square
From the top to A: 1/16" cut out (behind the steel).
From B to C: 5/32" cut out.
From D to E: 5/32" cut out.
From F to G: 5/32" cut out.
From H to K: 1/2" cut out (to fit behind #1 piece).
The two holes are countersunk drilled from the back side and the screws are installed from the back side.
Of the four long edges, only the back side to the rear corner is beveled, 7/32".
At the top is a countersunk hole for a wood screw.
Insert the finished piece in position and mark this top hole.
If this info is what you want, I will be glad to give you rear window dimensions.
Vern (Vieux Carre)
Last Name: Patrick
Post by jiminbartow » Wed Feb 23, 2022 12:20 pm
Wow! Why does it cost so much? Those pieces look pretty simple to make. Can you salvage what you have? There are epoxy resins (“LiquidWood” www.Abatron.com) that when brushed in and allowed to penetrate deep into the wood and allowed to cure and harden, convert soft dry rotted wood into a strong hard piece. Jim Patrick
Post by Jerry VanOoteghem » Wed Feb 23, 2022 12:35 pm
Classic Wood Products lists the 26/27 Coupe body wood at $246.00. That's all the body wood, except for the top wood. That doesn't seem so unreasonable, except that you just want the wood framing bits, which makes it harder to swallow.
As others encourage, make your own. It's only wood. If you screw up, there's more wood out there just waiting for you. BTW, when you're done, quote us the price you would make those same pieces for, if we wanted you produce some for us. ;)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Wed Feb 23, 2022 1:10 pm
Let me encourage the O.P. by saying that I only had the left side and built the right side in reverse with simple tools.
The old piece, unpainted 21-1/2", was originally on the left and needed to be replaced.
The lower block on the right was tapered with a hand held belt sander.
Vern (Vieux Carre)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Feb 25, 2022 10:53 pm
Found back side photos of lower wood that shows the cut out.
This is the left side.
Vern (Vieux Carre)
Post by John kuehn » Sat Feb 26, 2022 8:57 am
Did you call classic wood? In the past when you called them they would make the pieces you need and not the whole kit. But you have to call them and ask.
daveclause
First Name: D
Last Name: R
Post by daveclause » Sat Feb 26, 2022 7:10 pm
Yes. I did call Classic Wood. The price suddenly jumped from $246 to $348 when I called. The guy said that they are still showing old prices from years ago.
daveclause
First Name: D
Last Name: R
Post by daveclause » Sat Feb 26, 2022 7:12 pm
Thank you, Varmint. Very detailed.
daveclause
First Name: D
Last Name: R
Post by daveclause » Mon Mar 21, 2022 4:55 pm
I went with FORDWOOD. The window wood kit was $326.70, which included shipping. It took about a month from the order date to shipping. They manufacture the parts in their family shop in Utah.
They kept me abreast of each step with emails of beginning manufacture and shipping and they marked each piece of wood with the part number because the part numbers denote where the wood is placed.
Very cool operation if you ask me.
