1926 - LOOKING FOR PACKAGE SHELF AND TRUCK LID LATCH
lirogo27
First Name: Lisa
Last Name: Goldberg
* REQUIRED* Type and Year of Model Ts owned: Bought my first T - a 1926 T Coupe - in March 2022!
Post by lirogo27 » Thu Mar 31, 2022 10:05 pm
Hi there. Just purchased my first ever Model T! It is a 1926 Coupe. I am looking for a 1926 package shelf and a trunk lid latch. I know there are quite a few on line sites that sell reproduced parts, but sometimes parts are on back order for quite some time. Does anyone know where to find both parts used? Thank you....Lisa
Last Name: Humble
Board Member Since: 2006
Re: 1926 - LOOKING FOR PACKAGE SHELF AND TRUCK LID LATCH
Post by Humblej » Fri Apr 01, 2022 7:38 am
Some parts like the package tray are not reproduced. Good used parts are found at swap meets, if you know what you are looking for and can wait to find it, that is your best resource. Langs has a lot of used inventory, unadvertised, you have to call them, and it changes often.
There was a package tray for sale in the MTFCA classifieds a few months ago that had a lot of BTTT back to the top re-postings, so that may still be available.
1926-27 package trays changed a lot, there are at least 3 different versions that I know of, all wood, half wood half sheet metal, all sheet metal with a wood front lip. I do not know if they are interchangeable. If you know what your car had that is good, if you have the remains of one that is better, if you just have a hole where it goes that could be difficult as there is no telling what you need. There are 2 different postings about covering the package tray with upholstery fabric, you can see what those look like, I think one was all wood and one was 1/2 wood 1/2 sheet metal. The all sheet metal package tray has the same or similar shape as the 1/2 and 1/2. The all wood is as it sounds, so you or someone handy with wood could make a new one from plywood, that might be the quickest and cheapest way to go, if your car will take the all wood configuration. The all metal version has some compound curves that I would not recommend to try to make from scratch, and to make without a full size pattern. The all wood is simple enough and cheap enough to do some trial and error versions to get something that works.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Apr 01, 2022 7:53 am
Call Chaffin's Garage in Corona. 951-735-4791
They have a lot of used parts as well as new.
lirogo27
First Name: Lisa
Last Name: Goldberg
Post by lirogo27 » Sat Apr 02, 2022 5:56 pm
THX GUYS. Will call Langs and also Chaffins....
daveclause
First Name: D
Last Name: R
Board Member Since: 2004
Post by daveclause » Sun Apr 03, 2022 2:04 am
HI...I received your email for the package tray.
It's still available.
I'm in Fontana,
It's original in pretty good condition for it's age.
Thanks, Dave
lirogo27
First Name: Lisa
Last Name: Goldberg
Post by lirogo27 » Sun Apr 03, 2022 10:07 am
Dave, Thank you! I am in Studio City. I sent you an email with my cell number. Would like to figure this out! I look forward to chatting with you.
lirogo27
First Name: Lisa
Last Name: Goldberg
Post by lirogo27 » Sun Apr 03, 2022 10:13 am
Humblej - I could not find the post you mentioned about covering with fabric? Will keep looking....
jab35
Last Name: Bartsch
Post by jab35 » Sun Apr 03, 2022 10:47 am
Lisa: This post may be of interest: https://www.mtfca.com/discus/messages/5 ... 1472254840 I don't think any 'All Wood' package shelf/trays were ever used. I believe the curved metal back with 3/4" hardwood shelf and wood front edge strip is early '26 and later ones had the all metal curved back integral with flat metal shelf with a wood front edge strip. Both are illustrated in the link. The curved back was never fabricated from wood in the improved Fords
As far as I am concerned, Don Booth is the resident forum expert on the 26-27 body, roofs, interiors etc, and adding his name to a search request usually improves the result.
And if you are stuck for measurements of the wood parts, send a pm and I'll get back to you,
good luck, jb
Last Name: Humble
Post by Humblej » Sun Apr 03, 2022 11:47 am
There are also some good pictures of an early package tray in the Ford Service Manual fig 541, 542, 545, and 546.
lirogo27
First Name: Lisa
Last Name: Goldberg
Post by lirogo27 » Mon Apr 04, 2022 9:46 pm
Thank you Humble. I did pull and print them...
