Aux trans requirements?
Post by Steve Jelf » Tue Apr 12, 2022 12:53 am
When you install a Muncie, Warford, Chicago, etc., I understand that calls for shortening the DS tube and radius rods. Does the drive shaft also have to be cut and welded, or are there short drive shafts made for this?
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Re: Aux trans requirements?
Post by tman1913 » Tue Apr 12, 2022 1:08 am
Birdhaven makes shorten shafts for the KC Warford.
They maybe able to help.
Post by Wayne Sheldon » Tue Apr 12, 2022 1:30 am
They have been made special for auxiliary transmissions. However almost every one of the different transmissions was a different length, by anywhere from a half inch to several inches. So no one shortened driveshaft can fit more than a few transmissions.
Generally, driveshafts were shortened by re-machining one end or the other. Which end usually depended upon whether the shop was better set up for the keyed taper or the straight square.
I once did one myself, with a bench grinder and hand tools! I used an era crankshaft cutting tool to cut the forward end to fit the torque tube's front bushing, then using a bench grinder with home-made go-no-go gauges carefully shaped the square to a perfect fit for the U-joint.
It CAN be done!
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Tue Apr 12, 2022 2:00 am
All of those things have to be shortened. The tubes I cut and machine the ends square, then weld. On the shafts I cut the front end off and machine the bushing surface and u joint square back on in the right spot.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Tue Apr 12, 2022 2:10 am
Post by speedytinc » Tue Apr 12, 2022 8:51 am
I would add that I assemble the D/S & tube before welding the tube back together. When cooled its a quick check for any possible misalignment by feeling for any binding.
Post by Steve Jelf » Tue Apr 12, 2022 9:35 am
While we're at it, what about the radius rods? Does it matter where they're shortened? Near the front? Near the rear? Middle?
MWalker
Last Name: Walker
Post by MWalker » Tue Apr 12, 2022 10:25 am
For the radius rods, I cut them to length by removing part of the front end; the threaded parts are often no good anyway. Then I buy some 9/16" x 6" bolts, cut the heads off, bend them to fit, and weld them into the radius rods.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Apr 17, 2022 3:23 am
Whatever you do, DO NOT cut and weld the driveshaft! It's not if it will fail, but when it will fail(and it will), then you have no brakes. :shock: Do as was posted, machine either end to fit. Dave
1925 mostly original coupe.
