Any T owners near Smithville or Sparta Tennessee?
Topic author - Posts: 465
- First Name: Bob
- Last Name: McDaniel
Just checking who might live in the area that owns/drives a T.
- First Name: Rick
- Last Name: Rice
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Re: Any T owners near Smithville or Sparta Tennessee?
I'm right up the road in Gainesboro, TN
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
Bob,
Two (2) MTFCA Board Members are from Tennessee. George Akin and Ricky Williams have contact information in the inside cover of the Vintage Ford Magazine. If you reach out to them, they can let you know who may be geographically near.
Best of luck,
Dom
Best of luck,
Dom
- First Name: Jim
- Last Name: Eubanks
There are plenty of us in ET including George.
- First Name: Bob
Gainesboro is pretty close, I have been through there but it's a little hilly for me. Which direction from Gainesboro are you Rick? North? South?
I will look into the local chapters in the area soon. Hoping to find someone close enough to meet up with and do some cruising once we get our T down that way this summer.
- First Name: Ricky
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 12 Com. Rdstr, 12 Delivery, 2-12 Tou, 15 Tou, 21 Cpe, 25 Cpe 25 TT, 26 TT, 27TT, 26 PU, 26 Tou, 2-26 4dr, 26 Del, 27 4dr
We would love to have you in the Tennessee T's. Google Tennessee T's and check out our website.
Ricky Williams, President
Richard Williams, Humboldt, TN
President, Tennessee T's inc.
There is a Member search available on the Forum. Several options for selection. You need to be logged on for the member search option to be used.
When using Location you need to use both the State abbreviation and a second inquiry with some letters of the beginning of the State name (like tenne vs te to avoid getting members in Texas) the fields are case insensitive (lower/upper no difference).
The * is just a wild card to ignore following letters. You need to be logged on for these links to work!
This is the result of Location TN https://mtfca.com/phpBB3/memberlist.php ... el_t_type=
This is the result of Location tenne https://mtfca.com/phpBB3/memberlist.php ... el_t_type=
To use the search (you must be logged in)
1 click on Extra Quick Links, that will cause Search for Members to appear
2 click on Search for Members that will cause the search parameters screen to appear
3 fill in Location as described above
4 click on SEARCH
5 a list of members will be returned but you need to scroll down to see them
-- repeat steps 3, 4, & 5 for other search criteria
4 click on SEARCH
