How much torque for a wrist pin bolt, and how much for rod castle nuts?
Thanks!
How much torque?
WayneJ
Topic author - Posts: 541
- Last Name: Jorgensen
How much torque?
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
Re: How much torque?
Perhaps more important than the torque applied to the wrist pin bolts is how that torque is applied. The piston/rod assembly needs to be held by the wrist pin when torquing the pin bolt. I have two dummy spiggots which go in each end of the wrist pin, and then the whole is held in a vice while the bolt is tightened. Otherwise you run the real risk of twisting the rod if it is held while the bolt is tightened.
Hope this helps.
Hope this helps.
Kerry
- Last Name: van Ekeren
Some who like to use a torque value say 30lbs. I still do it Henry's way of by feel, Also as Allan has posted, hold by wrist pin when tightening the bolt, the pin is hollow so slide onto a phillips screw driver in a vice, also remember that the wrist pin bolt faces the cam shaft when assembling engine.
I use a piece of rod held in the vice and go by feel also, using an original Ford wrench.
Adding: Forgot because I have not used it yet, I have a piston vice.
ABoer
- First Name: Anthonie
- Last Name: Boer
I use this ;
Toon
Just like mine Toon. They hold the pin tightly with no slop at all.
I also use a piston vice & a rod through the pin. Rod bolt nuts I also hand tighten by feel - I assume if one's intent on utilizing a torque wrench, I believe a grade 5 bolt is 6-8 lbs. per 1/8" - Model T rod bolts are 3/8" so close to 24 foot lbs.
