Magneto recharge in Car
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Post by Dave Young » Sat Apr 30, 2022 1:56 pm
We just did an in-vehicle mag recharge in a buddy’s car using Tom Carnegie’s method as he outlined in a March 26, 2015 post. I’ve done the compass way multiple times in the past but definitely like Tom’s the most by far. The outcome was excellent. Car now hand-crank starts on mag beautifully. Thanks!
Last Name: Hatch
Re: Magneto recharge in Car
Post by Dan Hatch » Sat Apr 30, 2022 3:27 pm
How about a link?
Last Name: Kuehn
Post by John kuehn » Sat Apr 30, 2022 3:59 pm
Yea! Would like to see that to.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Apr 30, 2022 4:01 pm
When Dave gets back from enjoying his trip with a strong magneto, I'm sure he will be back on the Forum !! Great work Dave !!
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Sat Apr 30, 2022 4:36 pm
A link please and I’ll wait.
Post by Scott_Conger » Sat Apr 30, 2022 5:33 pm
Dave Young
First Name: David
Last Name: Young
Post by Dave Young » Sat Apr 30, 2022 11:38 pm
You nailed it, Scott! Posting links is a little above my pay grade. I fix stuff. Sharing a YouTube link is about as high tech as it gets. That’s why I had included the date at which it had appeared. Anyhow, that 36 volt jolt made the engine “bang” for each of the 8 quick taps of the jumper cable against the hogs head. I was impressed.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon May 02, 2022 7:45 am
I have a 40 Volt/40 Amp Battery Charger that was originally used to charge six golf cart batteries and I restored.
Charger Front.JPG (72.65 KiB) Viewed 1667 times
I removed the switch that would turn it on for 8 hours and then turn it off and replaced it with a push button switch.
Holding the button in for 10 or 15 seconds gave a better charge that the 3 short push button zaps.
One time the connection fell off the terminal, drew a lot of sparks and popped a circuit breaker.
The compass would point north any place on the transmission cover or the pedals.
The cover was removed and tested again to show one small area that would let the compass point south below the starter area.
There is an error in most of those drawings that show the distance from the terminal post to the compass edge and that number is correct to show the distance from the terminal post to the pin the compass needle pivots on.
The other charge to the top problem that worked for me was to remove the spark plugs, put the transmission in neutral, and lift a rear wheel to remove any drag.
Then hold the button in for about 10 seconds and the engine will turn a little to aline the magnets for a good charge.
