Model A Crank
Lyndon
First Name: Lyndon
Last Name: Moore
* REQUIRED* Type and Year of Model Ts owned: 8
Model A Crank
Post by Lyndon » Thu May 12, 2022 1:39 pm
I hear all the time which Model T's had the best crankshaft. But if you are using a model A crank, I never hear which to use for them. I have plenty of both designs of Model A cranks. So I do not want to use the wrong ones if one is better. Are there any other differences besides the thickness of the throws?
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: Model A Crank
Post by got10carz » Thu May 12, 2022 2:36 pm
30 years ago a old boy that raced T's told me that the bottom one in your picture can't be broke. I mentioned this to one of the current engine builders, he said he wouldn't use one. Who knows. Either one is better than a stock T Crank! Have someone experienced in shortening cranks do that.
Re: Model A Crank
Post by speedytinc » Thu May 12, 2022 3:38 pm
The bottom, "beaver tail" crank was the one the old time local racer guys said to run.
J and M Machine
Last Name: Gulbankian
Re: Model A Crank
Post by J and M Machine » Thu May 12, 2022 7:03 pm
We've seen more of the earlier beaver tail version of the Model A crack than the later style rounded style crank.
As with any crank you can say one is better than another, the only test worth doing is to have it wet magnafluxed.
Les Schubert
First Name: Les
Last Name: Schubert
Re: Model A Crank
Post by Les Schubert » Thu May 12, 2022 7:36 pm
My favorite
My favorite
Cut down to A size “C” crank!
First Name: Henry
Last Name: Lee
Re: Model A Crank
Post by Henry K. Lee » Thu May 12, 2022 7:48 pm
Even with all the holes drilled in a Model A crank..., Never seen one close to being balanced. Ford pretended to pay his people well and they pretended to work by just drilling random balance holes!
