A Chart for Engine Knocks
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Tue May 24, 2022 3:55 pm
I’m looking for a chart that lists the type of knock a motor is having and the chart will suggest whether the rods bearings need to be adjusted or whether the mains need to be adjusted, or maybe a bent or twisted conn rod. It’s been a while since the chart has been on the forum, I think, and I’m unable to find it through searching.
For instance, I’m having a slight tapping at about 25-30mph when there is no load on the motor. Speed up, slow down, or retard the spark a notch or two and the noise goes away. This noise just started after a one-day ride.
If you saved the chart could you please post it?
Re: A Chart for Engine Knocks
Post by Scott_Conger » Tue May 24, 2022 4:44 pm
Bill
I think you're looking for this: https://www.mtfca.com/books/Course.htm
It is a worthy read, especially for those who are relatively new to the hobby
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Tue May 24, 2022 6:52 pm
That is a very educational and informative link and I'm going to save it. But, that is not what I'm looking for. The chart that I've seen for the past 20 or so years is much more detailed and deals only with engine KNOCKs.
Last Name: Wrenn
Post by TWrenn » Tue May 24, 2022 7:04 pm
The Ford Service manual...a.k.a. the "black bible" does have, albeit relatively short and to the point, a section that talks about engine knocks, and their proposed remedies.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Wed May 25, 2022 3:06 am
This old post includes a copy of a page from Dykes manual.
“Causes of Engine Knocks.”
https://www.mtfca.com/discus/messages/4 ... 1404141864
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Wed May 25, 2022 8:36 am
KBurket- THAT's it! Thanks.
Last Name: Wrenn
Post by TWrenn » Wed May 25, 2022 9:29 am
Also try Pg. 244-245 in the Ford Service Manual
