Need spark plug nut
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Need spark plug nut
Post by Emeraude » Tue Jun 14, 2022 6:44 pm
I lost the small nut that holds the plug wire on the plug.. I tried a 6/32 nut but was the wrong thread. Is there a nut that can be gotten without buying a plug?
Inthegarage
Last Name: Mosher
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
Re: Need spark plug nut
Post by Inthegarage » Tue Jun 14, 2022 7:04 pm
Home Depot carries the top nut for the spark plugs I don’t remember the size of hand sorry but someone will chime it
Post by speedytinc » Tue Jun 14, 2022 7:10 pm
In the back of my infertal mind, I recall the same issue from many years ago. The plug top thread was metric.
The solution was to get brass thumb nuts & re tap to the plug's metric thread.
jsaylor
Last Name: Saylor
Post by jsaylor » Tue Jun 14, 2022 7:13 pm
Autolite and MotorCraft use 7mm. Champions ate 8/32. Langs has the Knurled type in both sizes.
Post by John kuehn » Tue Jun 14, 2022 7:56 pm
Ace hardware has a good selection of various brass nuts.
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Tue Jun 14, 2022 9:39 pm
I've got a good selection of nuts that was in a box. Let me take a look tomorrow and see what I have. If I find any I'll send what I have. Don't worry about the shipping. I have some stamps I need to burn up.
Bryce
Post by Scott_Conger » Tue Jun 14, 2022 9:43 pm
there are a number of different threads on different "T" plugs, and a number of different versions of nuts, PLUS there are some nuts advertised as being correct and while they fit, they are far from correct!
show the plug, and the nut that fits (that is missing) and you'll get more certain help
Post by Rich Eagle » Tue Jun 14, 2022 10:08 pm
Many of my Champion brass top as well as the new ribbed plugs are #8-32 thd. Some of the Champion X plugs are smaller, #6-40 (I revise this to #5-40 per Steve's post below). I have some 14mm plugs with #8-36 thds.
What make are your plugs?
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Jun 14, 2022 10:44 pm
If you were closer, I would tap the thread on another nut you the thread size you need. Like previously said there is no std for this application.
Art Mirtes
Post by Steve Jelf » Tue Jun 14, 2022 11:57 pm
Early Champion X plugs take a 5-40 nut. Later Champion X (brass hat) are 8-32. The latter are easy to find with a google search. 5-40 plug nuts are made of unobtainium, so I bought slightly smaller ones and ran a 5-40 tap through them. I haven't researched thread sizes of modern plugs.
Post by Rich Eagle » Wed Jun 15, 2022 11:41 am
Thanks for that Steve. I rechecked 6 of them and they are #5s rather than # 6 as I had stated. You may want to recheck yours. Mine are all 40 threads per inch. Still, they are "made of unobtainium". Standard # 5 taps are 40 tpi and 44 tpi.
Post by Scott_Conger » Wed Jun 15, 2022 11:49 am
these folks have helped me out on some of the more unusual stuff: https://drillsandcutters.com/search?q=5-40+tap
Post by Rich Eagle » Wed Jun 15, 2022 11:53 am
Thanks Scott, I meant the #5 knurled nuts are made from "made of unobtainium".
Sorry for not being clear.
Post by Scott_Conger » Wed Jun 15, 2022 11:54 am
I should have realized that :oops:
Post by Jerry VanOoteghem » Wed Jun 15, 2022 11:56 am
Do you have some idea as to approximately where it was lost? My point in asking, is that many of us have "heard of other people" who have dropped the nut into an open spark plug hole. If so, it's gotta come out...
Post by TRDxB2 » Wed Jun 15, 2022 12:09 pm
I know someone who has done that. Since its brass, I tried to vacuum it out without success (wet/dry vac with no bag). Going to pull the head.
Post by Steve Jelf » Wed Jun 15, 2022 12:14 pm
OOooops! My memory slipped a cog. Rich is right. The early plugs take a 5-40 nut. Corrections made.
Post by Rich Eagle » Wed Jun 15, 2022 12:37 pm
If I may, here are 2 cuts from the Lang's site. They do offer the #5-40 as well as the #8-32 if these are still available.
They seem to be made out of Brass rather than unobtanium as we had thought. :D
Post by Steve Jelf » Wed Jun 15, 2022 11:21 pm
Mein gott! $6.24 a nut! I believe in supporting our parts dealers, but I'll spend the money on things I can't get elsewhere, especially when elsewhere is a fraction of the price (71¢ on Amazon). I love Lang's, but not for plug nuts. :)
Post by Rich Eagle » Thu Jun 16, 2022 2:10 pm
I feel your pain Steve. $24.95 hurts me more than $6.24 a nut. :D I might make some if I needed but I'm not using those plugs in anything right now.
Still, I was delighted to see they weren't impossible to find. I wouldn't make them for less money to sell.
It's been a good thread.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sun Jun 19, 2022 6:39 pm
This is how I learned to retrieve stuff like terminal nuts from cylinders.
https://gus-stories.org/august_1967.htm
Tom Miller
Post by TRDxB2 » Sun Jun 19, 2022 9:07 pm
Not sure what you found on AMAZON but not all knurled nuts are alike. Lang's is selling original style nuts for those seeking originality.
Orig n.png (102.95 KiB) Viewed 3891 times
Orig 5-40.png (90.96 KiB) Viewed 3891 times
For the rest who are looking just for a functional solution and are content function over form there are other choices.
I found this seller on ebay - has several items (ignition wires etc ) for hit-mis engines that could be used on a T Considering free shipping and a close knurl design plus one spare
https://www.ebay.com/sch/i.html?_ssn=zk ... c=1&_pgn=1
Post by Steve Jelf » Sun Jun 19, 2022 10:49 pm
I bought 4-40 nuts and ran a 5-40 tap through them. I don't imagine they're an exact reproduction of the originals, but I expect a small fraction of 1% of the people who see them will know that. As the old saying goes, close enough for gummint work.
