Need spark plug nut
Emeraude
Topic author - Posts: 87
- Last Name: Loranger
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring
Need spark plug nut
I lost the small nut that holds the plug wire on the plug.. I tried a 6/32 nut but was the wrong thread. Is there a nut that can be gotten without buying a plug?
Inthegarage
- Last Name: Mosher
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
Re: Need spark plug nut
Home Depot carries the top nut for the spark plugs I don’t remember the size of hand sorry but someone will chime it
In the back of my infertal mind, I recall the same issue from many years ago. The plug top thread was metric.
The solution was to get brass thumb nuts & re tap to the plug's metric thread.
jsaylor
- Last Name: Saylor
Autolite and MotorCraft use 7mm. Champions ate 8/32. Langs has the Knurled type in both sizes.
Ace hardware has a good selection of various brass nuts.
Bryce S.
- First Name: Bryce
- Last Name: S
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster
I've got a good selection of nuts that was in a box. Let me take a look tomorrow and see what I have. If I find any I'll send what I have. Don't worry about the shipping. I have some stamps I need to burn up.
Bryce
Bryce
there are a number of different threads on different "T" plugs, and a number of different versions of nuts, PLUS there are some nuts advertised as being correct and while they fit, they are far from correct!
show the plug, and the nut that fits (that is missing) and you'll get more certain help
Many of my Champion brass top as well as the new ribbed plugs are #8-32 thd. Some of the Champion X plugs are smaller, #6-40 (I revise this to #5-40 per Steve's post below). I have some 14mm plugs with #8-36 thds.
What make are your plugs?
Art M
- First Name: Art
- Last Name: Mirtes
If you were closer, I would tap the thread on another nut you the thread size you need. Like previously said there is no std for this application.
Art Mirtes
Art Mirtes
Early Champion X plugs take a 5-40 nut. Later Champion X (brass hat) are 8-32. The latter are easy to find with a google search. 5-40 plug nuts are made of unobtainium, so I bought slightly smaller ones and ran a 5-40 tap through them. I haven't researched thread sizes of modern plugs.
Thanks for that Steve. I rechecked 6 of them and they are #5s rather than # 6 as I had stated. You may want to recheck yours. Mine are all 40 threads per inch. Still, they are "made of unobtainium". Standard # 5 taps are 40 tpi and 44 tpi.
these folks have helped me out on some of the more unusual stuff: https://drillsandcutters.com/search?q=5-40+tap
Thanks Scott, I meant the #5 knurled nuts are made from "made of unobtainium".
Sorry for not being clear.
I should have realized that
Do you have some idea as to approximately where it was lost? My point in asking, is that many of us have "heard of other people" who have dropped the nut into an open spark plug hole. If so, it's gotta come out...
I know someone who has done that. Since its brass, I tried to vacuum it out without success (wet/dry vac with no bag). Going to pull the head.Jerry VanOoteghem wrote: ↑Wed Jun 15, 2022 11:56 amDo you have some idea as to approximately where it was lost? My point in asking, is that many of us have "heard of other people" who have dropped the nut into an open spark plug hole. If so, it's gotta come out...
OOooops! My memory slipped a cog. Rich is right. The early plugs take a 5-40 nut. Corrections made.
If I may, here are 2 cuts from the Lang's site. They do offer the #5-40 as well as the #8-32 if these are still available.
They seem to be made out of Brass rather than unobtanium as we had thought.
Mein gott! $6.24 a nut! I believe in supporting our parts dealers, but I'll spend the money on things I can't get elsewhere, especially when elsewhere is a fraction of the price (71¢ on Amazon). I love Lang's, but not for plug nuts.
I feel your pain Steve. $24.95 hurts me more than $6.24 a nut.
I might make some if I needed but I'm not using those plugs in anything right now.
Still, I was delighted to see they weren't impossible to find. I wouldn't make them for less money to sell.
It's been a good thread.
TMiller6
- First Name: Thomas
- Last Name: Miller
This is how I learned to retrieve stuff like terminal nuts from cylinders.
https://gus-stories.org/august_1967.htm
Tom Miller
Not sure what you found on AMAZON but not all knurled nuts are alike. Lang's is selling original style nuts for those seeking originality. --Steve Jelf wrote: ↑Wed Jun 15, 2022 11:21 pmMein gott! $6.24 a nut! I believe in supporting our parts dealers, but I'll spend the money on things I can't get elsewhere, especially when elsewhere is a fraction of the price (71¢ on Amazon). I love Lang's, but not for plug nuts.![]()
For the rest who are looking just for a functional solution and are content function over form there are other choices.
I found this seller on ebay - has several items (ignition wires etc ) for hit-mis engines that could be used on a T Considering free shipping and a close knurl design plus one spare
https://www.ebay.com/sch/i.html?_ssn=zk ... c=1&_pgn=1
I bought 4-40 nuts and ran a 5-40 tap through them. I don't imagine they're an exact reproduction of the originals, but I expect a small fraction of 1% of the people who see them will know that. As the old saying goes, close enough for gummint work.
