Hogshead question
Robert Lawson
Last Name: Lawson
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1924 Coupe
Hogshead question
Post by Robert Lawson » Sat Apr 13, 2019 1:28 pm
Can you use an earlier hogshead on a 26-27 engine?
Last Name: Humble
Board Member Since: 2006
Re: Hogshead question
Post by Humblej » Sat Apr 13, 2019 2:52 pm
No, not with a 26-27 transmission.
Post by Mark Gregush » Sat Apr 13, 2019 3:25 pm
Sure you could, but you would have to use the narrow 25 back brake band. The 26/27 brake band was wider and its center was moved back as was the pedal to match.
Robert Lawson
Last Name: Lawson
Post by Robert Lawson » Sat Apr 13, 2019 3:39 pm
Thanks for the info. I knew the brake band was wider but didn’t know if the pedal would line up.
Post by Mark Gregush » Sat Apr 13, 2019 4:09 pm
The wider brake drum is wider to the rear, the front sits in the same place as the narrow drum. So you would only be using the front part of the drum.
Post by Scott_Conger » Sat Apr 13, 2019 7:45 pm
As you can see, the answer is "yes". I have a late transmission in my '23.
The question you didn't ask is: "Will an early hog's head on a '26-27 engine need any reinforcing?"
The answer to that is a a most definite "YES!" Your late hog's head on a late engine bolts to the back of the engine and provides considerable stiffness to the crankcase. You will not have that with the early hog's head. With a 4 dip pan and early hog's head you really must run corner stiffeners (which should be there already) as well as a belly band under the crankcase. To do otherwise really risks breaking the crankshaft (sooner or later).
