Tire Tube Size
soonerdg
Last Name: Galbraith
Tire Tube Size
Post by soonerdg » Fri Jun 24, 2022 3:00 pm
Hello All!
I'm brand new to the forum. This is my first post.
I have a 1925 Coupe that I inherited from my grandad. It has been in a barn for the last 20+ years and I'm working on getting it back in running condition.
Model T small.jpg (90.47 KiB) Viewed 2376 times
First thing to address is the tires. I've recently ordered the tires and tubes, however, the tubes that were shipped to me are 440/550-21 instead of 440/450-21.
My question is, can I use these tubes in the 4.4/4.5-21 tires?
Thanks and looking forward to gaining some valuable knowledge on this forum.
Last Name: Humble
Board Member Since: 2006
Re: Tire Tube Size
Post by Humblej » Fri Jun 24, 2022 3:25 pm
Never saw 440/550 before, but that just means the tube will fit a 440 up to 550, they stretch and baloon, so, yes a 440/550 tube will work fine in a 440/450-21 tire which you have.
Last Name: House
Re: Tire Tube Size
Post by George House » Fri Jun 24, 2022 3:42 pm
Yes, those tubes will fit in, I hope, new tires. Welcome to the Forum and world of Model T s Dan ...You’ll have a lot of learning opportunities ahead of you on the way to enjoying sheer fun with that coupe. As examples: proper operation of split rims, ensuring you don’t have babbitt thrust washers in the rear end and the joys of lubrication. There’ll be helpful instructional manuals to buy and I’d recommend framing a lubrication chart you’ll get from your favorite vendor in your first order. Others will chime in to fill in the blanks 😁
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Re: Tire Tube Size
Post by Pat Branigan Wisc » Fri Jun 24, 2022 3:44 pm
Be careful when removing not to destroy the old tubes! They are probably better than the new ones! They will hold air for years where the recent ones need filling quite often. The latest that sound to be very good are Blokey.
Last Name: House
Re: Tire Tube Size
Post by George House » Fri Jun 24, 2022 3:47 pm
😂 Blokey 😂😂... he meant Blockley tires 😂
Re: Tire Tube Size
Post by Steve Jelf » Fri Jun 24, 2022 11:35 pm
Here you go, Dan. A couple of links for anybody new to the Model T game:
https://dauntlessgeezer.com/DG80.html
https://dauntlessgeezer.com/DG79.html
soonerdg
Re: Tire Tube Size
Post by soonerdg » Tue Jun 28, 2022 1:37 pm
Thanks for all of the replies. I found someone who would mount the tires and I should get them back today. I’ll post pics with the new “shoes”.
Looking forward to really getting into this!
First Name: craig
Last Name: leach
Re: Tire Tube Size
Post by Craig Leach » Wed Jun 29, 2022 10:57 pm
Hear Hear George,
It never fails to amaze me the number of people that think model T's where lubed for life at the factory.
