Any suggestions on removing bearing races from front hubs?
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Sat Jul 02, 2022 12:03 pm
This is not my favorite task. I have beaten these out with a long chisel and hammer in the past to remove the ball bearing style, but thought I'd ask for suggestions now. Maybe a little heat on the race or the hub might help? Thanks.
ChrisB
First Name: Chris
Last Name: Brancaccio
Re: Any suggestions on removing bearing races from front hubs?
Post by ChrisB » Sat Jul 02, 2022 12:14 pm
Run a weld bead on the bearing surface of the race and they will fall right out when it cools.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post by Steve Jelf » Sat Jul 02, 2022 1:43 pm
A variation on the welding suggestion would be to weld a small piece of scrap metal across the cup and whack it out from the back with a drift and BFH if any persuasion is needed.
Post by Allan » Sat Jul 02, 2022 10:45 pm
Once you have them out, make the internal divots which allow the use of a drift to drive out the later tapered bearing cups. Steve Jelf shows how to do this in previous posts.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Sun Jul 03, 2022 3:45 am
All the hubs have a recess inside to allow a long punch to fit through to tap the race out.
Post by Allan » Sun Jul 03, 2022 4:38 am
David, the early hubs with ball bearings do not have the divots. Hence Steve's post about how to make them in the earlier hubs.
Post by speedytinc » Sun Jul 03, 2022 11:40 am
One must tread lightly here. There is not a lot of hub available to grind notches in.
The castings are quite thin.
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Sun Jul 03, 2022 1:51 pm
Thanks guys! That's all very helpful.
Altair
First Name: David
Last Name: Menzies
Post by Altair » Sun Jul 03, 2022 11:25 pm
I am a little confused, the parts books from 09 - 23 list the same parts numbers for the hub assembly and for the inner and outer races. I have a variety of early hubs some with narrow threads and some with wider threads, some have the notch only in the inner hub and some with the notch in both inner and outer, but the part numbers are all the same. Could this be a variance in the manufacturing?
