These mirrors often break or come loose where the post is soldered from the inside to the brass sheet. I repaired a loose post by running a bead of epoxy around the base. The first coat penetrated the crack and the second added strength. The epoxy appears as a dark ring at the base of the post.
I used the thicker epoxy and appied it with a bulb syringe like you use for nose drops.
Repairing a brass mirror
RGould1910
Topic author - Posts: 1211
- Last Name: Gould
- Last Name: Tannehill
- Board Member Since: 2002
Re: Repairing a brass mirror
