ZERK Caps?
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
ZERK Caps?
Post by Professor Fate » Fri Jul 08, 2022 3:28 pm
I was thinking about making up a cap with a grease fitting for the steering bracket to be able to force the grease around the steering shaft and bushing.
Anybody try this before?
Last edited by Professor Fate on Fri Jul 08, 2022 11:05 pm, edited 2 times in total.
________________
**FATE**
Last Name: Tannehill
Board Member Since: 2002
Re: ZERK Caps?
Post by JTT3 » Fri Jul 08, 2022 3:51 pm
That’s such a good idea that the vendors sell them if you don’t want to make one yourself.
Last Name: House
Re: ZERK Caps?
Post by George House » Fri Jul 08, 2022 5:06 pm
Yes; I’ve made them for all my “cup grease” fittings on all my T s. Just takes 2 different tap sizes. I placed a full grease cup in a vice grip and turned down the cup all the way and only had 2” of grease stream. Then I pumped one grease gun pump into a zirk screwed into another grease cup and was rewarded with 7” stream of grease. Much more efficient.
Re: ZERK Caps?
Post by Rich Eagle » Fri Jul 08, 2022 6:00 pm
They are a good idea.
I still enjoy filling the cup and screwing it down. Call me old fashioned.
Do what works for you.
Re: ZERK Caps?
Post by TXGOAT2 » Fri Jul 08, 2022 6:02 pm
A pot of red grease and a putty knife ...
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: ZERK Caps?
Post by MichaelPawelek » Fri Jul 08, 2022 7:15 pm
When you mass grease 8 cars, 2 tractors, 3 trailers and 2 riding lawnmowers in one session….😀
Professor Fate
Last Name: S
Re: ZERK Caps?
Post by Professor Fate » Fri Jul 08, 2022 8:47 pm
I've been filling the open fitting and pushing the grease in with my thumb. Easy but takes too long. Got other stuff to get done most of the time.
...... and I know the vendors sell them..... I wanted to possibly make my own.
Last edited by Professor Fate on Fri Jul 08, 2022 10:14 pm, edited 1 time in total.
________________
**FATE**
Re: ZERK Caps?
Post by Norman Kling » Fri Jul 08, 2022 8:56 pm
I don't think I would want one on the steering box. One reason it would look very noticeable. The other is if you have too much grease in the steering box, it will bleed out and get on your lap.
Professor Fate
Last Name: S
Re: ZERK Caps?
Post by Professor Fate » Fri Jul 08, 2022 9:05 pm
Sorry Norm, I meant the steering bracket at the frame, at the bottom of the shaft by the pitman arm. The bracket with the long brass bushing I just replaced....
I apologize
________________
**FATE**
Re: ZERK Caps?
Post by TXGOAT2 » Fri Jul 08, 2022 10:38 pm
"I've been filling the open fitting and pushing the grease in with my thumb". ////// I use a putty knife to fill the screw-on cap with grease, then I thread it back on the base and give it a turn or two or three as needed. The flat knife makes it easier to get the cap full of grease with little or no air pockets.
Re: ZERK Caps?
Post by Steve Jelf » Fri Jul 08, 2022 11:51 pm
I put one in my U-joint grease cup. Larry pointed out that it's not original, but Arthur Itis overruled him. :)
Re: ZERK Caps?
Post by TRDxB2 » Sat Jul 09, 2022 1:50 am
Then there are these if you choose to replace press-in oilers with zerks
Professor Fate
Last Name: S
Re: ZERK Caps?
Post by Professor Fate » Sat Jul 09, 2022 2:22 am
Steve, 8 years ago I tried one of those in that exact spot. I found that I couldn't get the threads to start. So I never put it in. The old one got reinstalled. Too much "donkey" pain to be bothered at the time. Convenience became a project....
________________
**FATE**
