Seen on T bay
Topic author - Posts: 3744
Seen on T bay
There appears to be a mint 1913 KW coil box switch on ebay now, that is on a master vibrator. They are identical to the one used on the 1913 KW coilbox. All you need to do is put your correct plate on it. I have used these often. They are asking $100.
- First Name: Keith
- Last Name: Townsend
Re: Seen on T bay
I see two of them. (One is starting at $145) And they both have the Corbin brass plated "lunch box" style latches.
