Is a Foot Warmer dangerous?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon Jul 18, 2022 11:22 am
So I was up at Carlisle for the Chrysler show and came upon a foot warmer. The outside seems to be covered with what looks like rug material. Then it occurred to me. Is this made out of asbestos? I see them for sale on here from time to time.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Is a Foot Warmer dangerous?
Post by Erik Johnson » Mon Jul 18, 2022 11:48 am
Clark Heaters were insulated with asbestos which was covered by wool carpet.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon Jul 18, 2022 1:25 pm
I'll check to see if it has a manufacture on it.
jeffstag
Last Name: Versteeg
* REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Post by jeffstag » Mon Jul 18, 2022 3:27 pm
Even if there is asbestos under the rug material, it's safe as long as it's not exposed. If the rug is nice and tight all around, the asbestos would be considered encapsulated and would pose no danger. The problem would come if you were to try and, say, replace the rug and disturb the underlying asbestos material where you might get airborn fibers that you could breath in.
23 Touring
23 Fordor
25 TT
27 TT
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Mon Jul 18, 2022 4:39 pm
Probably only dangerous if you are barefoot…….
Post by speedytinc » Mon Jul 18, 2022 4:46 pm
Or spill out the burning coals. & dont pull the blanket up over your head for the extra warmth.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Mon Jul 18, 2022 5:46 pm
Do not use a glowing ember from the heater to look into the gas tank to see the gas level……
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon Jul 18, 2022 11:13 pm
Ha!! You guys are great. I've been out of the Marine Corps now for about 8 years and I miss people busting on me.. :lol: :lol: :lol: I looked at the rug and it does have a white layer wrapped around it under the rug. Even has a chunk of the black brick left over. I'll make sure I don't chew on it.. :P :P
Post by TRDxB2 » Tue Jul 19, 2022 2:09 pm
The Clark Foot Warmer using a charcoal brick. So as it burns Carbon Monoxide is being released inside the passenger compartment. Passengers then are subject to Carbon Monoxide poising - first headache, nausea they turn green and if not exposed to fresh air they may die. Asbestos dust & fibers are what's dangerous. Vinyl flooring installed between 1952 and 1986 likely contains asbestos, BUT if left undisturbed shouldn't be a problem. The same is true for hot water & heating units back when, but these require professional removal. Both require proper disposal.
Post by Rich Eagle » Tue Jul 19, 2022 2:28 pm
Headache, nausea and turning green. Isn't that just part of having a Model T? :lol:
Seriously, be safe and consider the possibilities. I have been warned about using the manifold heater in a closed car and have seen no problems so far but knowing there are possibilities is a good thing. An open car without side curtains would have better ventilation.
ironhorse
First Name: G.R.
Last Name: Cheshire
Post by ironhorse » Tue Jul 19, 2022 2:55 pm
Point about Carbon monoxide is moot in an open car with no side curtains..... as for a closed car how tight can you close it, you probably still get gobs of fresh cold air coming in. :evil:
Last Name: Strange
Post by CudaMan » Tue Jul 19, 2022 3:33 pm
I wonder if there is some kind of solid material that you could heat up in the microwave, then put in the foot warmer prior to a drive. No fumes! :)
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Jul 19, 2022 4:00 pm
Maybe time to wear electric socks ?..... Stay away from me asbestos, it does cause cancer.
Post by speedytinc » Tue Jul 19, 2022 4:58 pm
Electric socks would not be period correct.
Last Name: Strange
Post by CudaMan » Tue Jul 19, 2022 6:06 pm
The period aftermarket offered electric steering wheel hand warmers, but I couldn't find period heated socks. Jay? :)
http://www.mtfca.com/discus/messages/50 ... 1232033463
