I just purchases Kim's Automatic windshield and I may replace the brass setting channel. The stuff available from Speedway Motors is made for their reproduction frames. The Automatic frame has tighter corners so I will be bending the new pieces of setting channel to fit. The brass setting is thin and very difficult to to heat without making spaghetti. I am thinking about annealing it with low heat forming it over a piece of Masonite cut to the same dimension I need.
How does that sound?
Criticism pro and con welcomed.
Forming brass setting channels
RGould1910
Topic author - Posts: 1208
- Last Name: Gould
Re: Forming brass setting channels
The masonite former inside the channel is a start. However you will need a second component to prevent the channel spreading outwards. A piece of timber cut to the outside of the desired curve and just a tad thicker than the channel, can be backed either side with extra piece of timber to form a channel to hold the brass from spreading. Masonite may not be the best choice for the driver, as you may have to be a little to aggressive for it to stand up.
RGould1910
- Last Name: Gould
Thanks for the input, Allan. Thinking on it, I could make a dye by cutting two curves side by side out of wood and use spacers to get the right distance apart to keep the setting channel from spreading and a hard piece of properly shaped wood for the driver. I am hoping that using Speedway Motors setting channel with curves already present would be easier than starting with straight channel, do you agree?
Also thinking about using a little heat to anneal the channel. I would place the setting channel in a different driver that conforms to the the Speedway curve to keep it from noodling as I heat it.
Maybe annealing isnt a good idea, I don't know
Thinking as I type, do I need a bottom on the curved die to keep the brass from sinking down too low or will the ridges on the brass channel stay above the sides of the dye ?
I suppose I could cut a full length spacer board with a 1/4 inch greater radius to sandwich between the two others to give the dye a bottom.
How you make the former is up to you. It just needs some way to stop the brass going walkabout during the bend. I learned the former trick when bending C section aluminium for my D and F roadster. Bending it and keeping it flat required a former. For that job I simply cut a bend to the profile required and the used my table saw to machine a groove in the end, into which the C section fitted. Drawing it around that former was easy. Your material and the bending application is much different.
I would think annealing would be required. The thin material in glass setting channel would need very careful treatment, which others may be able to help with.
Good luck.
Good luck.
