Horn Picture
CatGuy
Topic author - Posts: 341
- Last Name: Hunt
- * REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Horn Picture
Can someone post a picture of a stock horn as would be found on a 26-27 T? I don't have one and would like to find one.
Mopar_man
- Last Name: Govoni
Re: Horn Picture
https://www.modeltford.com/item/6437B.aspx
This is the bracket you will need.
https://hkkeller.hibid.com/lot/29806-14 ... tric-horn/
This is what it looks like.
- Last Name: Tannehill
- Board Member Since: 2002
Re: Horn Picture
Re: Horn Picture
'26-'27 electric horn with the proper bracket to mount due to the coil box on the engine with the Improved Car
Note: Bracket is busted away at spot common to fracture due to shaky motor!
And easy to convert any late T elec horn to 26-27 just by changing the bracket.
CatGuy
- Last Name: Hunt
Re: Horn Picture
Thanks all! Very helpful!
CatGuy
- Last Name: Hunt
Re: Horn Picture
I'm chipping away at it.....slowly.... I now have the right side wheels back on and should have the left rear one on tonight. I found a guy that could weld the studs on the hubs/drums. Looks like it's going to work. The guy (Birdhaven) replaced the rebuilt generator with a new 6V alternator. The amps gauge still won't show a charge. Tonight after I get the wheel on I plan to go through the wiring.....again and see what is wrong. When I get a helper I plan to test the battery with the car running and see what that brings. I'm gaining. The car is a keeper, and if I ever get a bigger house/garage I might get another T or TT.......
Re: Horn Picture
- Last Name: Patrick
Re: Horn Picture
Here are 3 pictures of the original Ford script goose horn that was on my 1926 coupe when I bought my T in 1970. Jim Patrick
