Closed Cab Pickup ?
20touring
First Name: Kevin
Last Name: Mocyk
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Closed Cab Pickup ?
Post by 20touring » Mon Aug 08, 2022 3:34 pm
While I realize Ford never made a closed cab pickup, I wonder if I could get opinions on what year and model of closed car this one started out as. Sure looks nice!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Closed Cab Pickup ?
Post by Kevin Pharis » Mon Aug 08, 2022 3:52 pm
Shortened 4 door sedan...?🤔
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Mon Aug 08, 2022 4:01 pm
If that had a metal bed modified a bit to fit better to the back of the cab,that would be 1 of the coolest T's I have seen in a long time.
Last Name: House
Post by George House » Mon Aug 08, 2022 4:08 pm
‘24-‘25 coupe. LR fender points to ‘25. Rear of cab too nicely done for a sedan.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Aug 08, 2022 4:47 pm
While I can’t say for sure on this one, many of the closed Model T’s converted to closed cab pickups were done using 1924-25 or 1926-27 Tudor’s. On the 1924-25 T’s the Coupe’s attached deck made this conversion harder. I would say this T pickup was once a 1925 4 door in this case, because of short front doors from a 4 door and the 1925 rear fender although the front fenders look like they are the 1924 type with the exposed bead.
Post by TXGOAT2 » Mon Aug 08, 2022 5:08 pm
There is a 1926 Lincoln in this area that was given a similar treatment. Whoever did it did a first class job.
Post by Rich Eagle » Mon Aug 08, 2022 6:21 pm
I believe this shows that it was a 1924-25 Tudor. The door proportions, visor, cowl and splash apron look exact to me. The rear upper body panel does look different but I don't believe it is Coupe or Fordor. Maybe custom or extended. There is a vent in the cowl although not clearly seen. Coupe and Fordor doors were not that wide.
We had a '24 Packard and some Buicks with that treatment in our area. It was a typical modification.
It would certainly be a fun car.
P.S. This shows the same view of a coupe. Notice the narrower window and transition to trunk.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Aug 08, 2022 6:37 pm
This one is a shortened Tudor
Post by Rich Eagle » Mon Aug 08, 2022 6:43 pm
Another 24-25 Coupe comparison.
FWIW
20touring
First Name: Kevin
Last Name: Mocyk
Post by 20touring » Mon Aug 08, 2022 10:54 pm
Wow! Thank you one and all, this is some really great information. Makes it clear it was a Tudor.
Has anyone ever documented this conversion that would like to share their experiences?
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Aug 09, 2022 8:05 am
Bear with me here as Iam not advocating for hot/rat rods but this idea has crossed my mind. Taking a Tudor or fordor and adding a bed to the back of it. Obviously it would take some fabrication to the chassis components. Linda like the family extended cab/crew cab pickup.
this picture is only for the general idea. One with actual T body parts ,chassis ,wheels would be spectacular.
Post by Rich Eagle » Tue Aug 09, 2022 12:08 pm
I would have chopped it the other way.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Tue Aug 09, 2022 12:32 pm
Ha Rich, that must have been custom built for Robert Wadlow. :)
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Aug 09, 2022 1:09 pm
Rich I love it! For long journeys so you can stand up or for special occasions when you wear your 10 gallon top hat :lol:
Post by speedytinc » Tue Aug 09, 2022 1:21 pm
Or bring along 19 frat brothers.
