More 1922 Centerdoor
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Wed Aug 24, 2022 2:28 pm
Doing some test fitting on my Centerdoor.
Hood is slightly out of square.
And the notch for the PILLAR COUPE (that’s what the parts book calls it) is too big.
The sill was replicated by another person and does not match the dimensions of the partial original I have that came with the car
William L Vanderburg
1922 Center Door Sedan
Last Name: House
Re: More 1922 Centerdoor
Post by George House » Thu Aug 25, 2022 8:05 am
Sounds like you sure have your work cut out for you. Wish I could help....
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Sun Aug 28, 2022 10:38 pm
how are you window runs on the glass for the door mine is missing them not sure how to make them
Post by Allan » Mon Aug 29, 2022 2:40 am
The bends in the hood panels are infinitely adjustable. It is easier to make each one fit one at a time. You need to have the cowl lacing in place before starting. Take the side panels off, and re-bend the top panels until you have them following the body line. Do the same at the radiator end. Often overlooked on new hoods is the lack of a shallow bend at the hinge end at the front of the top panels. You need to put this bend in. Otherwise, when the hood is closed, the hinge rod will be lifted out of the keeper on the shell and your nicely adjusted hood will no longer fit as it should.
Once the top panels fit, refit the side panels and check your work. With luck, all will be well, but body/radiator/frame alignment may still give you headaches. We tend to strive for a fit which is often likely to be far neater than that achieved on the assembly line.
Hope this helps, Allan from down under.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Aug 29, 2022 1:07 pm
Mine are a latch system introduced in late 21 for the 22 models. The same as the front quarter glass.
