2 post hoist
Mikes 1912
First Name: Lester
Last Name: Husted
* REQUIRED* Type and Year of Model Ts owned: 20
2 post hoist
Post by Mikes 1912 » Mon Sep 19, 2022 7:02 pm
Has anyone used a 2 post hoist on a model T? What are the difficulties in using it if any? Thanks
Re: 2 post hoist
Post by Allan » Mon Sep 19, 2022 8:03 pm
Most will require extensions/alterations to the pickup points to be able to lift the car on the frame. I use my mate's hoist with two long lengths of 4 x 3" hardwood to pick up the front and rear axles. Others will have different ideas.
TLeroux
Last Name: Leroux
Board Member Since: 2010
Re: 2 post hoist
Post by TLeroux » Mon Sep 19, 2022 10:11 pm
you need extensions to pick up a T
I can give you part numbers on extensions if you have model number of hoist
I sell hoist and parts
tom 714-4123200
DickC
First Name: Dick
Last Name: Cruickshank
Re: 2 post hoist
Post by DickC » Mon Sep 19, 2022 10:18 pm
The reason I have a four post lift is because I didn't feel comfortable with long extensions. Just my opinion.
Re: 2 post hoist
Post by Steve Jelf » Mon Sep 19, 2022 11:05 pm
How about a one-post?
First Name: craig
Last Name: leach
Re: 2 post hoist
Post by Craig Leach » Mon Sep 19, 2022 11:14 pm
How about this.
Duey_C
First Name: Duane
Last Name: Cooley
Re: 2 post hoist
Post by Duey_C » Mon Sep 19, 2022 11:52 pm
Excellent lift photos and info! I've often wondered how to pick up a T on a lift also Lester.
An old work friend welded 4 floor extensions on his two post lift as he wasn't real sure about the 8 bolts to hold a vehicle safely.
Odd/off question: How can an old one post hydraulic lift be removed from a floor?
Love the stand-up stabilizers under one of those cars with another sitting close by on the other lift.
Must've been squashed under something in a past life. ;)
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: 2 post hoist
Post by Chris Haynes » Mon Sep 19, 2022 11:58 pm
Here is my Model A on my Two Post lift. Simple extensions available from the lift maker make it easy.
Re: 2 post hoist
Post by Allan » Tue Sep 20, 2022 12:30 am
I considered Craig's channel solution before opting for the wooden beams under the axles. They give me access to the wheels, brakes etc.
Chuck Regan
First Name: Chuck
Last Name: Regan
Re: 2 post hoist
Post by Chuck Regan » Tue Sep 20, 2022 1:29 am
Extensions to clear running boards - tall jack stands for insurance.
Last Name: Wrenn
Re: 2 post hoist
Post by TWrenn » Tue Sep 20, 2022 8:54 am
I'm with you Dick! Plus, a 2-poster absolutely must be very well secured to the floor. 4 posters of course are far more stable by design. The ramps really don't get in the way that much as some would think. When I run my F150 on it I also stick 4x4's under each ramp end at the post just for a little extra security
First Name: craig
Last Name: leach
Re: 2 post hoist
Post by Craig Leach » Tue Sep 20, 2022 11:56 am
Allan,
That's not mine I found the pic on the forum. I have a 8' ceiling the only hoist I have is a Loadstar on a 20' I beam for pulling engines.
AndyClary
First Name: Andrew
Last Name: Clary
Re: 2 post hoist
Post by AndyClary » Tue Sep 20, 2022 12:52 pm
I spent my career working with vehicles on hoists. I wouldn’t recommend a two post for a Model T. I drive on would give you all the access you need and be way gentler on your car. Also better for storage when your T reproduces.
Andy
Michael Peternell
First Name: Michael
Last Name: Peternell
Re: 2 post hoist
Post by Michael Peternell » Tue Sep 20, 2022 7:31 pm
Little gas station in Albany Mn still has one.
DickC
First Name: Dick
Re: 2 post hoist
Post by DickC » Tue Sep 20, 2022 8:01 pm
Not to be labor the point but I also use the four post lift for other cars and trucks. I have a Marmon that would require extensions to clear the running boards. I have worked under a car without extensions and working on the front of the car caused movement. Was it dangerous? I don't think so. If I used 12 inch extensions under the Marmon I would be scared.
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Re: 2 post hoist
Post by Mike Lebsack-Iowa » Tue Sep 20, 2022 8:49 pm
My personal opinion for what it is worth. I purchased an Advantage 4 post lift. It came with a rolling platform that can support 4500 pounds using a bottle Jack if you want to lift your car off the ramps to do axle work. I opted for an optional air over hydraulic scissor lift that rolls on the same tracks. It can lift 4500 pounds, has adjustable reach and height options, and has locks so it can settle down by accident. Best money I have ever spent for being able to really enable/enjoy wrenching and maintaining a T.
Mike
Mike Lebsack-Iowa
Last Name: Lebsack
Re: 2 post hoist
Post by Mike Lebsack-Iowa » Tue Sep 20, 2022 8:50 pm
Correction: the scissor lift has locks so it “cannot” inadvertently settle down.
