How Do I Install a Throttle Lever?
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I have installed a NH carb on my 1927 engine, so I need to install a lever in the hole in the rod. The hole is located about 10" below the present lever.
How do I get the rod exposed so I can slip the lever over the rod?
- Last Name: Hatch
Re: How Do I Install a Throttle Lever?
Ford made a bolt on lever just for this. T6297 I think. It was being reproduced, not sure if it still is.
Remove the pitman arm and lower support bracket. Then, remove all the paint from the throttle and timer rods, since it doesn't belong there anyway, (same with the steering shaft), and it will impede the installation of the lever. Then, slide the lever onto the throttle shaft & pin in place.
BLB27
- First Name: Bruce
- Last Name: Brakke
Describe how to remove the pitman arm and lower support bracket.
BLB27
- First Name: Bruce
- Last Name: Brakke
Clarify why the paint should be removed from the rods and steering shaft.
- Last Name: Patrick
Paint does not need to be removed as long as the thickness of the paint does not impede the movement of the levers rods and steering shaft. The paint does serve the purpose of protecting them from rust. Mine are painted. Jim Patrick
John.Zibell
- Last Name: Zibell
If your block doesn't have the hole (have you checked?) this is available. http://www.modeltford.com/item/6299CL.aspx
1926 Tudor
Follow the steps and photos in Ford Service, Chapter XXV, Steering Gear Overhaul. That includes removing the pitman arm ball, sometimes a gear puller is needed, sometimes just a lead mallet strike.
The timer lever arm has to be removed, by driving out the rivet, after that , just pull off the steering bracket from the shaft and the two rods.
Slip on the spacer bracket, that goes around the shaft and helps separate the two rods, then slip the new throttle arm up the throttle shaft, then be sure to index the arm so the long arm is pointed at the motor, with the lever at the quadrant moved all the way to the top. Rivet the arm to the throttle shaft, a small cut to length nail can be used as the rivet.
[/b]
1. I'd buy the kit that John Z recommended and use things as-is
2. Or I'd buy this, and be done with it https://www.modeltford.com/item/6297.aspx
since the steering bracket has never been off, then the bushing is undoubtedly original and worn. If you don't renew it, and don't restore everything on the front axle, you will have a pretty car that is constantly looking for a ditch.
jab35
- Last Name: Bartsch
Follow Scott's advice, check the bushing AND SHAFT for wear. My experience has been that both will be worn. Replacing the bushing will help, but the shaft may need to be built up to make the steering tight. YMMV, sincerely, jb
BLB27
- First Name: Bruce
- Last Name: Brakke
What is the best to check the shaft and bushing for wear?
fordt
- First Name: Rob
- Last Name: Trippet
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
While he’s getting into this, I’ll ask a similar question. Does this black “spacer/divider” stay in place anywhere or supposed to end up somewhere along the length of the shaft? I reckon left to it’s own it’d slide down to the carb lever anyway…
Is that your column Rob ? Reason for asking is there are small pins that go inside the spring retainer cups - not cotter pins outside - the cups are upside down.
fordt
- First Name: Rob
Oops! This is how they came off of Frankencar, easy enuff, I’ll swap that out! I reckon I thought it looked right because the springs went right into the cups! Thanks!
BLB27
- First Name: Bruce
- Last Name: Brakke
How is the best way to check the bushing and shaft for wear?
jab35
Pull the lower steering bracket, clean everything and measure the diameter of the shaft where it rides in the bushing. The shaft is probably worn to the extent you can 'feel' the difference between worn and original diameter, but a micrometer will quantify it. The wear on the shaft will not be uniform around the circumference. Build up the low spots with the mig and machine to original 0.750" diameter or throw about $250 toward a modern replacement steering shaft.
For the bracket, just replace the 7/8 x 3/4 x 1-1/4" bronze/brass bushing in the bracket (only one bushing in '26-'27). You will be pleased (and safer) with the results. jb
BLB27
- First Name: Bruce
- Last Name: Brakke
What is the best way to remove the steering bracket?
Remove it from what ??? The frame or steering column ???
BLB27
- First Name: Bruce
- Last Name: Brakke
From the steering column. The steering column is off the frame.
Scroll up this thread.
Post by DanTreace » Mon Sep 26, 2022 8:49 am
BLB27 wrote: ↑Sun Sep 25, 2022 9:41 pm
With the spark rod lever removed as Dan showed, put the steering shaft in a vise and tap the bracket off with a drift and a hammer.
BLB27
- First Name: Bruce
- Last Name: Brakke
Dan, Oops!! I should have remembered the 9/26 post.
