What have you done with your model T in October?
Ken Lefeber
Topic author - Posts: 70
- First Name: Ken
- Last Name: Lefeber
The weather this morning was perfect for a ride.
Made it home before noon.
Can you think of a better way to start your day?
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Re: What have you done with your model T in October?
Last week I reassembled my NH with a new to me B float, yesterday I installed it, today with some fresh Gas I got it started. Had trouble at first then discovered I forgot to adjust the mixture
. Made the adjustments and roared to life. Also replaced the sketchy filter screen
- First Name: Austin
- Last Name: Farmer
On Saturday, we got our 1920 Centerdoor out of the garage and moved it to another garage.
We took a ride in our 1925 Touring for the first time in a few months. I got to drive!
I had a lot of fun.
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
We took Betty, the TT, to a show in Lafayette, Colorado. There was good company with the '14 RPU Survivor, the 2 hp Witte hit & miss engine in Betty, and the 25 hp Witte hit & miss engine on the truck.
KeithG
- First Name: Keith
- Last Name: Gumbinger
Very interesting picture with lots of T's in it. I don't see any 1914 or earlier T's, they are the ones with straight rear fenders.
Keith
Keith
KeithG
- First Name: Keith
This got posted to the wrong thread. It should be in the thread abo9ut the 1920 Jitney.
Sorry about that.
Keith
Sorry about that.
Keith
hull 433
- First Name: Stan
- Last Name: Gadson
Put the hood on.
Carrying luggage with an accordion running board rack left some scrapes in the Tudor paint. I had saved some Dulux enamel and was able to find where I put it 20 years ago.
I first wet sanded the areas (about 3/8"). Then I daubed on some paint a little larger than the spot. Next, I brushed thinner around the edges to keep from getting a thick edge. I will let it dry overnight and repeat it 2 or 3 times making larger spots until the sanded area is covered. Dulux really doesn't dry hard and takes a long time. Next spring, I will try to sand it very lightly and then rub it out.
Pictures of black paint are so reflective they don't show well but I think the idea can be seen. It took about 50 pictures to get these.
Light gray primer shows right up when there is a scratch for better or worse.
The Dulux isn't as available as it was years ago but has held up well on several of my cars.
DROVE IT! With a friend. A mere 49 miles is all. Gorgeous day. Tomorrow it's a lunch tour with the guys!! Gonna be great.
The last time I drove the 22 Runabout, the generator was not charging. I tried flashing it across the cutout and it charged for a little while and then stopped. I tried a different cutout but it still didn't work. I have a 26 Roadster which has been parked over a year so I took the generator off it and tried it on the 22. While I was removing it from the 26 I dropped it and broke off the oil fitting on the end of it. After I put it on the 22 it didn't work either. So I have been driving the 26 Touring on which I replaced the headgasket last month. I think I finally got it fixed right, because it hasn't even needed any coolant added for several weeks even after about a 50 mile tour.
Anyway, today I drove the touring down to the local museum where we had a presentation for about 20 senior citizens who are in a class where they go around the San Diego area and visit the various historical museums. I parked it next to our buggy so they could see a horse drawn carriage along a horseless carriage. We had 3 groups of 6 or 7 people and 3 docents. So I was on my feet for about 3 hours and also just about wore out my voice. There are two houses there with displays inside each one and then outside are farm equipment and the vehicles as well as some other historical things in the barn. So our presentations were for about 1/2 hour each and when one group left and went to the next one etc, so I made my presentation 3 times this morning.
Yesterday I cleaned the commutator on the generator which I had taken off the 22 and it motored on a 6 volt battery. So I put it on the 22 and I used the crank to prime. When I turned on the ignition to batt, I got a free start. The generator works better now than ever. The one off the other car which I dropped has endplay in the shaft and the gear is kind of loose. I still have a few other generators and hopefully can get one to work so I can put it on the car which has been parked.
Thursday we have another group of seniors coming to the museum, so I will take the 22. It is 100 years old this year and looks more like a carriage than the 26.
mbowen
- First Name: Miles
- Last Name: Bowen
Joined the Borderline T’s on a 66-mile tour of the southeastern portion of Michigan’s “thumb”. Thank you Tim Juhl (OldAvi8tor) for putting this on!
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
- Last Name: House
Worked with the ‘fair wear and tear’ on my ‘26 tudor after the Texas T Party. Somehow lost the ammeter needle - replaced ammeter. Somehow broke the left emergency brake rod. Welded brake rod. Passenger door handle somehow became inoperable. Somehow ordered a new one from Lang’s
- Last Name: Hjortnaes
Miles
What app did you use to track your journey? Apple or Droid? Thank you.
Today was the 2nd good day in a row to tour so off I went. 60 miles yesterday overall, few guys had 75. Today I went out through a wetland area and beyond, but only did 31 miles! Still a great day again. Tomorrow not so much!
mbowen
- First Name: Miles
- Last Name: Bowen
I used a Stratus portable aviation GPS/traffic/weather receiver to record the tracks. I just turned it on and threw it in the back seat. After I got home I downloaded the tracks to an aviation app called ForeFlight (Apple only) and saved them as .kml files (a very common track log format). I then uploaded the .kml files to Google Earth to create the photo. There are apps that will do the same thing with just a phone, but this way I didn’t have to learn anything new except Google Earth, and that was fairly straightforward. (Google Earth allows multiple tracks to be easily displayed on one map, whereas I can’t get ForeFlight to display more than one).
Miles
I decided it was time to fix the separated rain rail on the Coupe. This photo was posted elsewhere.
download/file.php?id=143343&mode=view
Having tried to reattach it a few years ago it had come loose again. It was obvious why after pulling it back a bit. The Douglas Fir had rotted out at that point. It seems more solid elsewhere, but time will tell. Chiseling out the bad and making a poplar block to fit was my solution for now. West System's epoxy resin was applied liberally, and the block was clamped in place. The top material is still intact and could be retacked. Then I clamped the rain rail back into place forcing the previous nails into the new wood. Finally, a long wood screw will hopefully hold it tight for some more years. As I mentioned in the Foto of day post, I had made those rain gutters 9 years ago.
http://www.mtfca.com/discus/messages/33 ... 1380286211
As tacky as the Rusty Coupe is, it has some features which are more authentic than some nicely restored cars. These are the choices we make in the "What's correct and What's Not" department.
All just part of the game we play.
It makes me smile.
It makes me smile.
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Painted the 25 Touring a few days ago and starting to put some if it back together. I paint the body, fenders and other stuff separately, gives a better result. Shooting acrylic enamel and I will let it sit for a few weeks and then start wet sanding and buffing. That will help with some of the runs and orange peel... I think the acrylic enamel looks more authentic as compared to the urethanes.
Distagon2
hull 433, is that perchance the 15 Touring once owned by Ken Jones?
jab35
- Last Name: Bartsch
Ken Lefebre: What color paint did you use on your Coupe? Can you share the technical information with me? And if anyone else knows the recipe or modern equivalent for 'Channel Green', please chime in. Thanks, jb
jab35(at)Cornell(dot)edu
Driving Stanley, my Fordor now that cool weather is here. Also yanked the torpedo's front axle out to get it repaired next Wednesday.
Drove the 1920 Dodge to breakfast, again. Came home restaged were the T sat. Jacked all 4 wheels up off the ground. Looked at all the work still that still needs to be done and put the tarp back over it. Still waiting for the rods!
Ken Lefeber
- First Name: Ken
Jab35, The color of my coupe is channel green. It was like that when I bought it. I think it was an older restoration. Whoever did it, did a nice job.
jab35
They did an excellent job. Thanks for replying, jb
TMiller6
- First Name: Thomas
- Last Name: Miller
A school holiday in the south caused my daughter to show up here with my three grandchildren. My wife then celebrated her birthday with two daughters and a granddaughter. They ignored my request to stick to the four dollar menu and came back with numerous take away containers.
I promised my grandson that his uncle and I would make it up to him. So, we headed to the Ford Museum and then walked the Village. Lunch was at Ford’s Garage. The seven year old kid told our waitress that he’s an annual OCF participant so she insisted he come behind the bar and blow the oogha horn on the T Touring. He is excited about the two or three Garages planned for Knoxville and I had to promise onion rings once one opens.
My daughter returned home this morning so my son and I ended up at the shop pulling batteries and winterizing our Touring cars. We also surveyed what I need to finish my grandson’s Runabout so his mom and dad have something to drive at OCF 2023.
We also discovered that a 29 Ford crossmember can be fit in the frame backwards in spite of two old guys helping him do it right.
Tom Miller
kelly mt
- Last Name: Kelly
Time to replace the pads on my disc brakes. Pretty easy job.
- Last Name: Strange
A little early perhaps, but I unpacked and rolled out the side curtains and installed my home-made winterfront on my 1924.
Retro54
- First Name: Andrew
- Last Name: Blaydon
I drove it as transportation to our flea market spot at the Hershey Fall Meet! Had some fun conversations with some fellow Model T'ers and found the perfect spare tire carrier for it 1 row over from our flea market spaces.
It was "Draining Day" not to be confused with the Denzel Washington Movie.
We have had a couple of nights at 32° so it was time to drain radiators and put in antifreeze. I also drained the gas out of the cars I don't expect to drive this Winter. The Coupe was happy to receive the extra gas and postpone a trip to the filling station.
Others run antifreeze all year round, but I lose a few gallons and the water makes my pocketbook and the environment a little happier.
The No. 2 pencil keeps the incoming antifreeze from escaping down the overflow tube.
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Time for Lizzie's annual bath. We're invited again a week from Saturday to the "Trunk or Treat" the local repair shop puts on. It's kind of a car show, the kids vote for the car they like best. Lizzie cleans up pretty well for a "farm pickup"
- Attachments
- C960490C-4767-49E6-BB5E-6B69C95B3E94.jpeg (44.88 KiB) Viewed 13030 times
- First Name: Dennis
- Last Name: Seth
Rich,
Did you take your annual bath too?
Rich P. Bingham
- First Name: Rich
Perry, your insinuations about my personal hygiene are crude and unwelcome. I'll have you know that I, like my sheepdogs, bathe daily in the ditch, often several times a day in the summer heat. Alas, snow is predicted for Saturday, so it will be on with the red flannel long-johns until sometime next spring when the canals turn in and we begin irrigation once more. Annual bath. Faugh! A calumny, sir ! A calumny !!
Get a horse !
- Last Name: House
I aired up tires and pushed around several Model Ts in the barn to ‘uncover’ my 1911 restored Hupmobile runabout that I haven’t driven in many years. Will detail and service it in the next few days. Also removed the Simmons straight thru from the ‘26 Ford tudor that performed badly on a recent tour. Turns out it had no flapper and our friend Scott Conger emailed his reply of surprise it ran at all
so its being packaged for mailing to Corey Walker for flapper installation
Glad to hear that Corey can help you, George. That's a lucky break.
KLTagert
- First Name: Kathy
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1917 Runabout, 1918 Coupelet, ‘21 Centerdoor, ‘22 coupes, ‘23 Roadster and touring, ‘25 roadster pickup, Fordor, and coupe, ‘26 Coupe
Took the '25 Roadster Pickup to Graceville, FL for a car show to raise funds/gifts for needy children at Christmas. There were 199 awesome looking vehicles there and two Model T's. Lee Wolfe with his 1923 Touring and us. Both took judges choice. Our lil T also took "Best of Show Truck - Stock" .
Always a great day when the Model T is recognized and getting to talk T with folks there.
TheSaintDiscJockey
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
Just finished the new bed on the 1923 TT. [/size][/image][/b]
Beautiful! Love the stain color you chose.
- Last Name: House
That’s some mighty purty trophies for a mighty purty ‘25 roadster pickup
Good thing you were showing a pick up. Them trophies wont fit in a roadster.George House wrote: ↑Wed Oct 19, 2022 2:21 pmThat’s some mighty purty trophies for a mighty purty ‘25 roadster pickup![]()
Ken Lefeber
- First Name: Ken
My car was down for repairs last fall, so I'm taking advantage of the nice fall weather we are having this year.
I drove thru the Kettle Moraine State Forest today, the fall colors were at peak! Last chance for a burger, they close for the season tomorrow. Photo-op with one of the murals in town.
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
A tour date with the 2022 Melbourne Cup (Think Aussie version of the Kentucky Derby) The race that stops the nation, first Tuesday of November. The 2022 Melbourne Cup was touring my area stopping in the town where the 1915 winner was acknowledged with a statue. They were requiring a 1915 era vehicle to pose for photos with both the 1915 trophy and the yet to be awarded 2022 trophy. The 2022 trophy is valued at .75 Mil$ and is made of 24ct Gold. The 1915 trophy is priceless! A wonderful day.
mbowen
- First Name: Miles
- Last Name: Bowen
Put 116 trouble-free miles on Bonnie to get to and participate in the Central Michigan T’s Fall color tour.
Miles
Pep C Strebeck
- First Name: Joseph
- Last Name: M
I made a new set of top straps for the Runabout:
I used the original footman loops and rings for the rear straps, but new tongueless buckles. Both of the original buckles had been broken. I had found a post on the old Forum from R.V., and he gave the correct length for the woven web straps:
http://www.mtfca.com/discus/messages/82 ... 1523326947
The hardest part was finding the correct webbing. Most all of the cotton webbing that is sold is more fashion-over-function: too thin (0.075" +/-0.005 vs. 0.108" +/-0.005) and not as tight of a weave. A genuine military web belt is the right thickness, but wrong width, you need a 6L webbing, 1" wide. Thicker and tighter weave, 6L on the left and the thinner webbing on the right.
I was fortunate enough to get a couple of n.o.s. buckles/hooks for the front straps from Bob Bergstadt, as the originals had been lost long before I got the car.
Drove, drove and drove it some more! The Fordor for 3 days last week and Clarabelle the '13 got a big workout the last two days and a short run Saturday afternoon. Great late season weather with gorgeous colors.
- First Name: Dallas
- Last Name: Landers
I have been too busy to enjoy the T's much this year. Tucked them both in for winter and pulled the batteries. This work thing gets in the way of T time.
TFan
- First Name: Jim
- Last Name: Riedy
I managed to make it to 75 years on Wednesday and I wanted to drive my T 75 miles to celebrate but weather was not conducive to this on my bday sooo! Tim Wrenn set up the proceeding tour on Sunday And what a beauty I went out beforehand and put some miles on and then hooked up with the rest of the gang for an enjoyable afternoon of touring. I managed to put exactly 100 miles on old Herkermer. And we are going out again tomorrow. Jim
But the funny part of the story above is, when we all left the ice cream shop in Vermilion, unbeknownst to me, Jim went a slightly different direction and met us at that bridge in the pic above! I told the wife I was a bit worried if he was okay when I realized hee wasn't "back there" (vibrating mirrors!), altho I was sure he would call on the phone if he needed help. So, it was vroom vroom for Jim!
Happy belated birthday Jim!
See ya soon in Havanna for our last "T lunch tour" probably!
TFan
- First Name: Jim
- Last Name: Riedy
Tim, Are you trying to say I've got a lead hand. Vroom vroom indeed. Jim
mbowen
- First Name: Miles
- Last Name: Bowen
TFan wrote: ↑Mon Oct 24, 2022 11:35 pmI managed to make it to 75 years on Wednesday and I wanted to drive my T 75 miles to celebrate but weather was not conducive to this on my bday sooo! Tim Wrenn set up the proceeding tour on Sunday And what a beauty I went out beforehand and put some miles on and then hooked up with the rest of the gang for an enjoyable afternoon of touring. I managed to put exactly 100 miles on old Herkermer. And we are going out again tomorrow. Jim
I did a 66-mile tour on my 67th birthday earlier this month; I should have driven once more around the block! Also, I love the name “Herkermer”; how did you come up with that?
Miles
Went on an awesome Fall Tour hosted by Mike & Joyce Catlin. An overnighter at The Shack in Jugville, MI. (I also ate ice cream)
Man that ice cream looks good! Now I'm hungry!!
Gen3AntiqueAuto
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Brought mine back from the dead in Oct...
https://youtu.be/Wj8Xy9KhIBQ
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
TFan
- First Name: Jim
- Last Name: Riedy
Miles, I believe the name came from an old Looney Tunes cartoon character from what I can remember. Kind of a slouchy guy with a straw hat and a big Adam's apple. Jim
Gen3AntiqueAuto
- Last Name: Foye
Arbs
- Last Name: A
- Board Member Since: 2022
I picked up a '23 Touring and we love it. My son and I have been getting it running and preparing for some winter projects i.e. (new bushings, band linings, bearings, fixing leaks, etc.)
Arbs
- Last Name: A
Waiting for trick-or-treaters...
Bryant
- First Name: Bryant
- Last Name: Shafer
Tweeked, Blasted,primed,painted the frame. Refurbished the front spring and axle beam. Working on the rear spring. Applied slip plate to both spring packs and waiting for some new repo OEM shackle kits and oiler cups to show up. Most of all having fun with it!
Bryant
Bryant
Distagon2
I have started the re-restoration of a 1912 Commercial Roadster that was owned by the late Ken Jones. I have a set of wheels being built at Stutzman's. The car was not assembled when I got it, although the parts were pretty well organized, so I am figuring out how everything goes together. I have restored a 1926 Coupe and a few Model A's, but I have to say these early brass T's are in a league of their own.
Distagon2
Actually, it is probably more accurate to say that I am "finishing the re-restoration" that Ken Jones started but, unfortunately could not finish. And I am starting to feel like I am the only person on earth actually restoring a brass car nowadays!
My son and his family wanted their family photos with one of the T's. So for the grandkids, grampa had to install the battery and get it out of the shed where it spends the winter
After all that , Kelly and I drove it to town for supper
Corey Walker
- First Name: Corey
- Last Name: Walker
Last week I finally found what I believe to be the correct for January 1914 mag post. It came with one like is at the left. Then I ordered one and it was a modern type, then about 10 years ago I got the 3rd one but I believe it is 1915-1917. So after 25 years I finally believe I have the correct one (far right). I know you can’t see it, but I know it’s there.
Then those combination hex/slotted screws are hard to come by so I thought try making some. I made the bottom 2. They’re pretty close to the top 2 originals.
I have since found enough good magnets for my speedster flywheel. I need to replace the triple gear pins before I do anything else.
joe.wal
- First Name: Joerg
- Last Name: Walther
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
- Board Member Since: 2014
With unusual good weather and high temperatures I did a last drive this year after changing to anti-freeze and before the T was prepared for sleeping the next 5 or 6 months.
1916 Touring
I am cleaning some hub bolts today. It's nice to see the bare steel.
A sleeve protects the threads while spinning and sanding/brushing the crud off. A wooden block holds the other end.
These are ones I saved a few months ago:
viewtopic.php?f=2&t=371&start=100#p240598
Something calming about that kind of work Rich. I enjoy those days when can do things like that. At the end of the day you can see what you have done.
mbowen
- First Name: Miles
- Last Name: Bowen
230 miles for the month. 1487 since I started keeping track on May 30.
Miles
