Shimming a Motometer
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Thu Oct 06, 2022 9:02 am
Is there a way you can make a homemade shim out of (something) for a Motometer? Lately, ours has not lined up straight, and has a tendency to vibrate loose very quickly. What material could you use? Thank you!
Last Name: Wrenn
Re: Shimming a Motometer
Post by TWrenn » Thu Oct 06, 2022 9:28 am
Austin, I, like many others share your pain! I ended up starting out with the neoprene gasket, then adding various numbers of the old fashioned cardboard gaskets the vendors also sell. I also found that using teflon tape on the threads really helps, even if it it isn't "period correct"! :lol:
Last Name: Patrick
Post by jiminbartow » Thu Oct 06, 2022 9:43 am
Buy a half dozen of the cardboard gaskets (only .40 ea. from Lang’s and put enough into the neck to allow you to tighten the motometer enough to position it to the front and tight enough to keep it from vibrating loose. I have 4 of the gaskets in mine. It won’t work loose if you tighten it tight enough. Jim Patrick
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Oct 06, 2022 10:04 am
I have a rubber gasket plus one card board gasket, which worked for me. Never a problem since.
Art Mirtes
Post by Norman Kling » Thu Oct 06, 2022 10:35 am
I go to the hardware store and get a neoprene gasket made for a sink drain. They usually have one which fits just right. It is soft enough that I can usually line up the motometer with just a little pressure on the cap to seal. If it is not facing the right way, then just one or two thin gaskets made of gasket paper on top of the neoprene one.
Post by RajoRacer » Thu Oct 06, 2022 11:05 am
Do you have wings or a dog bone ? I use an o-ring + a gasket or two to line up the cap to the radiator quite snug then I loosen the motometer nut and twist it ever so slightly towards the driver's side and snug it back up.
tvw
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 22 touring
Post by tvw » Thu Oct 06, 2022 11:24 am
Mine came with 2 thicknesses of rubber gaskets made from inner tubes :D
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Thu Oct 06, 2022 12:02 pm
Our car has a dogbone.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Thu Oct 06, 2022 3:51 pm
My Grandpa made some homemade ones, I wonder if I can find some of those somewhere. He used some sort of yellow plastic. Sorry I do not have any pictures.
Post by Norman Kling » Thu Oct 06, 2022 4:03 pm
One has wings, the other two have dog bones. However the one with wings got too hot and got stuck all the way at the top, and I can't get it down. So one of my 3 cars has just a standard cap now.
Post by Allan » Thu Oct 06, 2022 7:24 pm
My son came home with a 6" long, 2" diameter red Nolethane boat trailer roller one day. Some time later I discovered that it was the diameter of the T radiator neck. I chucked it in the lathe, and using a common garden variety hacksaw, cut some washers by rotating the roller ans sawing at the same time. Naturally they come at different thicknesses. If one does not suit, another will, but they will also take a deal of crush, so aligning mascots is not a problem.
Eventually, they crack from the centre hole outwards, and after about 3 years they need to be replaced. The small centre hole allows the washer to be pulled out with a crooked finger.
Post by John kuehn » Thu Oct 06, 2022 7:42 pm
25 Touring
A good material to make Motometer gaskets is pieces cut out of a Purex or Clorox bottle. Prestone antifreeze bottles work good to. Farm fix as some would but they do work.
Luxford
First Name: Peter
Last Name: Kable
* REQUIRED* Type and Year of Model Ts owned: 1911 Town Car 1913 Speedster 1915 kampcar
Post by Luxford » Fri Oct 07, 2022 7:14 am
I use a radiator hose the same diameter as the radiator neck.
You can make it as thick as is needed ( cut with a utility knife) to get the motometer to sit correctly and the hose is usually reinforced with canvas or similar and the rubber is more than able to cope with the temperatures involved and you will have replacements anytime you need one depending on the length of the hose.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Oct 07, 2022 9:07 am
I wold like to thank you all for the ideas for I'm sure what is a very common problem. :D
Probably just end up making one of each! :lol:
Last Name: Hjortnaes
Post by DHort » Fri Oct 07, 2022 12:22 pm
I buy these at any hardware store. I think they work better than the gaskets.
I assume Art and Norm use one similar.
Post by speedytinc » Fri Oct 07, 2022 12:25 pm
YES, These work very well.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sat Oct 08, 2022 10:40 pm
There it is Dave! I didn't remember what it was for.
Works just right here too. A slight compression that I always worry about but the dog-bone never moves.
bobt
Last Name: Thompson
Post by bobt » Sun Oct 09, 2022 5:48 am
I just went to my Home Depot and bought two. $1.88 each. THANKS! bobt
