26/27 cowl lacing
elliott1936
Last Name: Elliott
26/27 cowl lacing
Post by elliott1936 » Sun Oct 09, 2022 12:54 pm
I'm about to install the cowl lacing on my 27 model T cowl ,and was wondering which way the brass rivets would be installed. The rivets are two prongs that go through the lacing. Are they installed from the outside or the inside of the cowl?
Re: 26/27 cowl lacing
Post by DanTreace » Sun Oct 09, 2022 1:54 pm
Installed like band lining, split rivet into the lacing, head inside the cowl….best done with gas tank out, that’s how the factory done it :)
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Sun Oct 09, 2022 4:03 pm
When I did mine the gas tank was in. Previous restorer used pop rivets. I took the rivets and filed the sides down so the rivet sat in the groove better
Last Name: Patrick
Post by jiminbartow » Sun Oct 09, 2022 11:34 pm
They are installed from the inside. The two prongs are spread and curved into and embedded into the lacing. You will need a friend on the inside holding the rivet head tight against the inside of the cowl while you spread the prongs. This is one job you cannot do alone. Jim Patrick
elliott1936
Last Name: Elliott
Post by elliott1936 » Mon Oct 10, 2022 1:23 pm
Thanks for the information. I will have a helper when I do this job. My son is helping me get my number 28 speedster back on the road with a new body style. Tom
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU (in progress)
Post by fordt » Mon Oct 10, 2022 4:01 pm
Wow, just now putting my gas tank in the dash and happened to see this! THANKS! I’ll put this on first!
Post by Allan » Mon Oct 10, 2022 7:01 pm
With the tank out, the rivets can be installed tangs out in the webbing as the factory fitted it, BUT, the two lowest on the sides will need different treatment because the rivets there cannot be inserted due to a double panel precluding same. Was the second panel fitted after the webbing? Most restorers resort to pop rivets at this location.
