Removal of 1926 fuel cover on cowling
dacapt1948
Topic author - Posts: 16
- First Name: Phil
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1926 tudor
How do you remove the cowling fuel cap hinged cover? 1926.
- Last Name: Humble
Re: Removal of 1926 fuel cover on cowling
Two screws on the hinge go thru the cowl and are held by two nuts. All are accessible with the gas door open.
Mark Nunn
- Last Name: Nunn
Accessible and removable are mutually exclusive, in my opinion. I could not get enough of a grip on screw heads to loosen them. Maybe soaking in Kroil will help.
John.Zibell
- Last Name: Zibell
Try 50/50 Acetone and ATF mix. Works better than commercial penetrating oils.
1926 Tudor
dacapt1948
- First Name: Phil
- Last Name: Terry
Thank you all
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Never turn a screw or bolt if it has a nut. Always hold the head hard with a well fitting driver and turn the nut. If it is a screw only, tap it as you turn in to assist breaking it loose, then tap as you loosen it.
Work honestly
Stay true to your word
Get the job done right
Petrah Phyre
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Using this formula, do you mix it up as you need? My thoughts are that the acetone would flash off if not kept in an air tight container.John.Zibell wrote: ↑Wed Oct 12, 2022 2:12 pmTry 50/50 Acetone and ATF mix. Works better than commercial penetrating oils.
jab35
- Last Name: Bartsch
Sean: I've got some in a pump type oil can and after 5 years it smells good and works well. You do need a closed container/oil can to reduce acetone evaporation, but the pump can does this. jb
Petrah Phyre
- First Name: Sean
Thanks James. I do have couple gallons of Kroll, but, as you are well aware, a couple gallons won't last forever when working on old stuff.
