New LED bulbs for Miss Molly, my 23 Coupe
Steve King
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
Board Member Since: 2010
Post by Steve King » Wed Oct 05, 2022 9:25 am
New LED headlight bulb on left versus incandescent on right. 23 coupe with 6 volt not running. Just purchased 2 headlight and 2 tailight bulbs from LEDLIGHT.COM for a total of $56 for the 4 bulbs including the shipping. I have no affiliation with this company. I bought the 6000k bright versus 3000k warm. I know that it doesn't look original, I want them bright as possible. Aiming is another story I can't speak to yet. My experience in my 30 Tudor is LEDS light and reflect the road lines and signs better along with being somewhat brighter. I suppose 12volt would provide higher Lumens. My other experience with incandescent bulbs is, 1 of the filaments of 1 of the bulbs can just about fail every other ride.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: New LED bulbs for Miss Molly, my 23 Coupe
Post by Erik Johnson » Wed Oct 05, 2022 11:33 am
Is that a Minnesota Pioneer license plate #338 on your car?
If it is, I can tell you to whom the plates were originally registered.
Steve King
Last Name: King
Post by Steve King » Thu Oct 06, 2022 6:59 pm
Erik, I bought it from Stan's widow. It was kept at Stan's model T Shop at the Scott Carvers Fairgrounds in Jordan MN. It was there for a very long time. So I think the plates were theirs. The motor number matches the title.
Steve King
Last Name: King
Post by Steve King » Thu Oct 06, 2022 7:09 pm
She is a sweet Coupe. I probably have a few hundred miles on it already in just a few weeks.
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Fri Oct 14, 2022 2:20 pm
I have played with some Led bulbs not happy with any of them bright to look at but don't shine down the road . Yes I have new reflectors also. can't move the bulbs enough to get the focus right.
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Fri Oct 14, 2022 4:09 pm
Thinking of new LED headlight bulbs also, has anyone had any experience with the ones that Snyders’s are selling.
Thanks John M
Oscoda Michigan
Steve King
Last Name: King
Post by Steve King » Fri Oct 14, 2022 8:03 pm
My darling bride Linda and I came home with the Coupe after dark the other night and she admitted that we could see much better. I will be putting them in my 28 Huckster too.
Steve King
Last Name: King
Post by Steve King » Fri Oct 14, 2022 8:06 pm
The tailight is much better also.
Post by Allan » Sat Oct 15, 2022 2:07 am
Tom D, to focus model T lights requires a pinpoint light source like the original globe filaments give. The parabolic reflector is responsible for the reflection of the beam. As far as I know, there are no LED globes which can be focussed, as there are multiple let's affixed to the base. They do give off lots of light, but it is just a big, unfocused blob.
Modern led lights have multiple reflectors to direct the light from each led. Each reflector is specially designed for the application.
Post by TXGOAT2 » Sat Oct 15, 2022 10:08 am
An LED light unit could be designed to fit in the Model T headlight shell. It would not look original.
The best chance of having good lighting on a T might be to see if one of the many motorcycle units could be adapted. Harley Davidson sells a good 12 V LED, plug and play hi/lo beam unit that resembles a 7" USA sealed beam unit and fits the later model, classic-styled HD headlight shell. One of these might fit a T shell with minimal modification. It would not look at all original from the front.
Luke
First Name: Luke
Last Name: P
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by Luke » Sat Oct 15, 2022 5:00 pm
Incandescent bulbs are not exactly a perfect point source of light either (particularly the early ones), the filaments are a good 1/4" - 3/8" long.
In my view there is no need to replace the reflector if you're using LEDs, and as Steve has confirmed here in practice you will in fact get a significant improvement to your ability to see and drive at night. Who knows, that better light may just assist in saving your car and you from injury one day.
If you want to know a bit more about the technicalities behind this, along with some headlamp history, this thread may be useful to you: viewtopic.php?f=2&t=25440
Luke.
Post by TRDxB2 » Sat Oct 15, 2022 6:01 pm
Some definitions to help understand terminology and what affects what.
Lumen (aka Footcandle) measures the amount of light produced, its the measurement of light output or brightness on a one square foot surface 1 foot away from the source.
Lux measures the amount of light produced, its the measurement of light output or brightness on a one square meter surface 1 meter away from the source. It is the metric counterpart of a lumen. 1 lumen = 10.57 lux
Candle Power (candela) measures the luminous intensity concentrated in a particular direction. Often used to compare spotlights & driving lights.
Watt measures the amount of energy used to excite the filament or light-emitting diode
Focal Point in a parabolic reflector it is the point where all reflected waves will be concentrated and projected forward. Light waves emitted outside of the focal point are scattered light. The adjustment screw on the Model T headlight is used to move the the light source filament or LED(s), to its most optimum point.
Fluted Lens has patterns in the glass surface to project the reflected light in a specific direction.
Kelvin measures the color temperature of the light. Although the whiter lights will appear “brighter” than those of a lower Kelvin reading, the amount of Lumens on the brightness scale does not change, and true brightness is not affected. So if two bulbs having the same amount of Lumens but one is 3500k and the other 6000k are shedding the same "brightness, but the colors of the objects being illuminated will make the 6000k appear brighter but in fact are lighter in color.
Tom Donnelly
Last Name: Donnelly
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Tom Donnelly » Tue Oct 25, 2022 10:14 am
Hey Steve,
Do you have any specific part numbers you can share for the Ledlight.com ones that you purchased?
Thanks!
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Tue Oct 25, 2022 1:18 pm
This is what I use.
Tom Donnelly
Last Name: Donnelly
Post by Tom Donnelly » Tue Oct 25, 2022 1:51 pm
Thanks so much Jim! Greatly appreciate! Product Code is 68523.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Tue Oct 25, 2022 2:23 pm
Those LEDs look pretty good! I guess some folks struggle with the incandescent bulbs, but here's my 6 volt OEMs- nice, brilliant white lights!...
RVA23T
Last Name: C
Post by RVA23T » Tue Oct 25, 2022 4:28 pm
Hey Steve,
Thanks!
This is what I chose to use 64975 is the part #, they do not do the high low due to the position of the pins so i have them set for a left to right at this time
BAY15D LED Headlightm pn 64975.png (64.32 KiB) Viewed 5756 times
Post by TRDxB2 » Tue Oct 25, 2022 4:49 pm
Illuminating the glass lens is not an indication of how much better the road is illuminated. I put led daytime running lights on my daily driver that were so bright they'd hurt your eyes, so I put a smoke film over them. Either way they have little effect in lighting the road ahead for more than 5 feet
Post by Allan » Tue Oct 25, 2022 8:10 pm
The last 3 posts tell a story, or not. In the first of the three there is a brilliant patch of white light produced, but no mention of what it looks like to oncoming drivers.
The next tells of no ability to be able to focus/direct the light.
The third, how effective is the light produced for the purpose intended.
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Tue Oct 25, 2022 11:05 pm
The flat style bulbs pictured above work well if the bulb is oriented horizontally. The original socket pin location orients the bulb in a vertical configuration. Modify the socket and the bulbs now cast a beam out in front of the car. Thanks to Bill Robinson, I changed the pin position and those bulbs work well.
Tom
Post by Steve Jelf » Tue Oct 25, 2022 11:49 pm
And then there are magneto lights, with widely varying voltage. As far as I know there are no LED's for that. Incandescent bulbs are the only game in town unless you rewire the headlamps for battery power.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Wed Oct 26, 2022 12:20 am
Steve drove the car to our Model T meeting on the 19th. The light output is good and the headlights do focus pretty well. It looks good oncoming and there is plenty of light to see where you are going, way more then your standard lights at much less amperage. He also has rear tail/brake led lights. Better vision and visibility is a big win for driving at night.
Last Name: Hjortnaes
Post by DHort » Wed Oct 26, 2022 12:46 am
I installed LED lights. They are bright enough that people have flashed me to turn down my high beams. However, when I am on a dark road they only help me to see the white line on the right if there is a white line.
Steve, which LED light did you purchase?
Maybe next time I drive to Rapids I will have to look you up.
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Wed Oct 26, 2022 1:49 am
I have a pair of the 9475 wedge shape led lights. Didn't like them. Way too bright and put out a funny C or U light pattern depending on whether your car has OEM or after market reproduction headlight sockets which almost always have the wrong pin orientation. If your lights are moving left to right when switching from dim to on sounds like you need to turn your sockets like Tom said. Turn them 90 degrees and drill a new mounting screw hole so the led lights are horizontal in the sockets. The bulbs have hi/lo when used in proper OEM socket. The wedge lights will work on a/c or dc 5 to 30 volts a/c so they will work on 6/12 volt cars and should work ok on a magneto but a minor wiring change at the headlights will be needed to put both bulbs in parallel.
Tmooreheadf
Post by Tmooreheadf » Wed Oct 26, 2022 9:38 am
There are new not as bright wedge type bulbs out now that have good led power but not the intense bright white. While they are better, they all our in the mid $20 range each. Until such time as these bright ones I have now crap out, the dimmer ones are not not on my radar.
Post by TXGOAT2 » Wed Oct 26, 2022 9:50 am
With a magneto-only car, using one of the magneto-powered, 12 volt charger devices and a 12 volt lawn tractor type battery would give you at least some LED light capability. A full wave rectifier device would probably give pretty good output, but might necessitate a "2 wire" 12 volt system, that is, one with both a "hot and "ground" wire to each 12 volt device. The wattage of bulbs used in the charging device would probably need to be adjusted to suit the full wave setup and the average expected load. I'd think a good mid size 12 volt battery and the regular half-wave, rectifier and bulb type magneto charging device would give several hours of LED lighting service.
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Wed Oct 26, 2022 11:16 am
I have LED taillights on a magneto-only car and they work well.
Seth Harbuck made them up for me years ago (I'm eternally grateful and thank you again, Seth, wherever you are), using a half-wave rectifier. They're hard wired to the magneto and come on when the car starts with no need to turn them on. There is no light bulb needed and no battery. There are six red LEDs in each light, one on each side of the car under the body so they're invisible standing around the car but are blazing bright when seen from the rear about 15 feet away. At night they're visible for two or three blocks.
Luke
First Name: Luke
Last Name: P
Post by Luke » Wed Oct 26, 2022 4:07 pm
A number of the posts here, where people are saying they have bright but unusable light, or odd patterns, are suggestive of an improperly focused system (the system comprising the light source + reflector, and to some extent the lens).
The link I posted earlier should provide most of what's needed to explain how all this works and I'd encourage you to read that. However if you just want the short version perhaps the main takeaway is that if/when you fit LED's you should adjust the focus, and you should do so without the lens in place. If you don't do this it would likely be more surprising that you got a good light pattern than not.
I expect there could be some LED designs that may simply not work well in the T headlamp system, but without a decent attempt at adjusting the focus you wouldn't be giving them a decent chance...
Luke.
Nunsio1
Post by Nunsio1 » Thu Oct 27, 2022 7:58 am
In previous posts it is mentioned that the high/low function doesn’t work because of socket & pin orientation. Snyders are selling LED headlamp bulbs with an adjustable base so contacts & socket pins line up. Has anyone purchased this bulb? Thanks John
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Thu Oct 27, 2022 10:17 am
I have them in my 15 touring and really like the way they light up. They were easy to install.
Fitz
