Weight of pistons
Magnusw
First Name: Magnus
Last Name: Wiberg
* REQUIRED* Type and Year of Model Ts owned: 1919 TT Truck, 1923 Touring, 1919 Touring , 1922 Pic up
Weight of pistons
Post by Magnusw » Wed Oct 19, 2022 4:24 am
Is there anywhere in the OLD , ORIGINAL Ford literature any information regarding the tolerance of the weight that the factory accepted when installing the piston/ rod assembly , when the model T was assembled at the factory in the teens and twenties?
I work on a 1919 engine and will use the lightweight cast iron pistons and rods that Ford introduced in 1924 resp. 1920.
Kerry
Last Name: van Ekeren
Re: Weight of pistons
Post by Kerry » Wed Oct 19, 2022 5:44 am
I'd have to say that never come across factory spec on weights, the Ford service book only stipulates that when replacing, that pistons are approximately the same weight.
I'm sure that would apply for a rod as well.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Oct 19, 2022 10:00 am
It has been written that a well charged magneto magnet should be able to lift a Ford piston, or about 3 pounds.
Post by TXGOAT2 » Wed Oct 19, 2022 10:16 am
I believe that Ford T engine assemblers made some effort to select and match piston weights. To what tolerance, I don't know. In the Model A era, considerable attention was given to selecting pistons and rods for weight matching.
Post by DanTreace » Wed Oct 19, 2022 12:41 pm
This is a authoritative source, of the process for balancing pistons in 1914, would assume later methods got pistons closer in weight allowed.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Wed Oct 19, 2022 9:17 pm
"The finished weights of Ford pistons vary maximum , about six ounces . Each piston is weighed and marked on the head by a center - punch used without a hammer , with one , two , three , or four center marks , dividing the pistons into ... (page 145)"
Model T Ford: The Car that Changed the World - Page 145
Bruce W. McCalley · 1994
