Brake pedal conversion
Robert Bente
Last Name: Bente
* REQUIRED* Type and Year of Model Ts owned: 1916 runabout, 1921 touring, 1915 touring
Post by Robert Bente » Wed Oct 19, 2022 11:59 am
I’m in the process of installing Bennett external brakes. I want to include the drum brake but need to adapt the peddle somehow so it has the cam.
Suggestions are appreciated.
Left picture is the peddle with a short shaft and no cam.
Bob Bente
Redding, Ca.
Re: Brake pedal conversion
Post by Jerry VanOoteghem » Wed Oct 19, 2022 12:02 pm
Weld an arm onto the original Ford brake pedal.
Post by speedytinc » Wed Oct 19, 2022 12:24 pm
Yes, that was the normal operation with R/M brake kits. They came with a piece of steel & location instructions for welding.
You can buy a new cast R/M brake pedal with cams.(May not say bennet)
I have seen recently on this forum a pedal like yours where cams from another pedal were crudely arc welded on. (May be in the for sale section)
Either way, you are wise to have/retain your inside brake function with your R/M brakes.
Post by RajoRacer » Wed Oct 19, 2022 12:45 pm
That's appears to be an early, original "Pike's Peak" pedal - I have one of each with no cam. I agree with John about retaining the internal service brake - can't have too many brakes on a Model T !!!
Last Name: Strange
Post by CudaMan » Wed Oct 19, 2022 1:35 pm
The vendors sell a RM brake pedal with the cam already installed, I have one on my 1924. Be careful installing it, don't drop a pedal spring down into the transmission and then have to fish it out like I did. :)
https://www.modeltford.com/item/RMB-PED1.aspx
Robert Bente
Last Name: Bente
Post by Robert Bente » Wed Oct 19, 2022 4:14 pm
Thank for the tips. I have a “pikes peak patent pending pedal” for trade towards a R/M pedal if anyone is interested.
Mark, I let a nut slip thru my grubby fingers. I’m hoping to flush it out thru the oil drain hole.
Bob…
Post by Scott_Conger » Wed Oct 19, 2022 4:24 pm
...I let a nut slip thru my grubby fingers. I’m hoping to flush it out thru the oil drain hole
One word answer: Nope
One word solution: Endoscope
Post by speedytinc » Wed Oct 19, 2022 4:37 pm
Bob…
Crap!!
Welcome to the fishing club.
You might want to review past fishing expeditions for how its done. Learn from our collective OOOPS.
"Hoping" & "flushing" aint gonna get it. The nut, if you could get it into the drain pocket, past the baffle, wont fit thru the drain plug hole.
It does give the opportunity to snag & attach a long wire to it. Dropped hardware must go out the same way it goes in. Sorry. Some folks will leave the nut in the sump, captured under the baffle plate.
Gotta love Scotts brevity.
Last Name: Strange
Post by CudaMan » Wed Oct 19, 2022 5:27 pm
Here's how I got the band spring out:
I used a flexible wand with a magnetic tip through the oil drain hole to find, touch and push the band spring up the back slope of the pan until a helper could see it through the inspection opening. It took multiple attempts, but eventually my helper exclaimed "I see it!".
With the spring visible from above and held there with the magnetic wand, I used a second wand with gripper tangs to grip the spring firmly and pull it up and out the top inspection opening. :)
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Thu Oct 20, 2022 11:41 am
Robert, I have a Bennet pedal minus the shaft that I would part with
