I measured the combustion volume of the head gasket. It is about 1.11 cu in. Is this taken into consideration whrn determining combustion ratio. The compressed gasket thickness measured .060 in
Art Mirtes
Cumbustion volume of head gasket
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Cumbustion volume of head gasket
Art- I agree, you number is pretty close to what I use.
Art M
Topic author - Posts: 988
- First Name: Art
- Last Name: Mirtes
Dan.
I am wondering how or where you otained your number I used an ancient drafting instrument called a polar compensating planimeter. I don't know how accurate it is. But must be fairly accurate since our numbers are close
Thanks for responding
Art Mirtes
Art Mirtes
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Perhaps I looked at this too simplistically.
Is it not the volume of a cylinder
Diameter 3.75 in
Height 0.060
3.14 X (3.75 / 2) squared x 0.060
I get about 0.66 cubic inches
Harry
Diameter 3.75 in
Height 0.060
Harry
Dan McEachern
- First Name: DAN
Harry-its the volume of a head gasket, which is not a cylinder, as you have to include the valve area as well. Art- its been several years, but I recall that my volume was an actual measured volume using a flat plate and a pipette.
