1926/27 Rear Axle in 1925 Touring
Tom Dove Jr
Topic author - Posts: 66
- First Name: Tom
- Last Name: Dove
- * REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1925 parts car(?)
- Board Member Since: 2022
All things being equal, would it be an upgrade to install the later rear axle assembly in a 1925 T??
Will internals interchange if needed?
Ultimately will be installing the Rocky Mountain brakes.
Thanks!
Tom
Thanks!
Tom
I have never let my schooling interfere with my education.
Education consists mainly of what we have unlearned.
Re: 1926/27 Rear Axle in 1925 Touring
That's what I have in my '25 Touring. Works fine. Yes, internals are the same. The "upgrade" is in having larger parking brake drums.Tom Dove Jr wrote: ↑Thu Nov 03, 2022 2:49 pmAll things being equal, would it be an upgrade to install the later rear axle assembly in a 1925 T??
Thanks!
Tom
ABSOLUTELY. I run one in a 23 touring, over 40 years now. I do not run RM brakes (actually removed them).
The big drum brakes are equivalent when maintained.
Moxie26
- Last Name: Jablonski
Tom.. if your engine number is into the vicinity of September of 1925, I would bet it would be acceptable to have the improved rear axle installed, since in all Ford upgrades there is no definitive day that all factories started using the changes.. they would have to use up the stock parts that they had before the change before the improved replacements...... Not related to your question but I could tell you that the 1922 touring at the Thomas Edison estate in West Orange New Jersey not only has the improved axle but it also has the four to one "mountain axle gearing" but also has other improvements installed that were tested before they made the assembly line.
Tom Dove Jr
- First Name: Tom
- Last Name: Dove
Jerry, Speedy, and Moxie, thank you!!
T
T
Tom Dove Jr
- First Name: Tom
- Last Name: Dove
Seems to me I recall hearing something along those lines. As I am always on the front end of maintenance, those $$$$ can certainly be used elsewhere.speedytinc wrote: ↑Thu Nov 03, 2022 2:56 pmABSOLUTELY. I run one in a 23 touring, over 40 years now. I do not run RM brakes (actually removed them).
T
- Last Name: Hjortnaes
You will also need new radius rods. They are shorter in the 26-27 axle.
Tom Dove Jr
- First Name: Tom
- Last Name: Dove
Fortunately those are part of the package.
Mark Nunn
- Last Name: Nunn
You may want to use your earlier spring perches unless you want to lower the rear of the car about an inch.
AndyClary
- First Name: Andrew
- Last Name: Clary
I have a large drum ruxtell in my ‘14. Main reason is I had one. Benefits, larger brake and I like the look of the drum more so than the flat Rocky Mountain add on drum. Did not change the height of the car.
Andy
Andy
