Exhaust manifold
G.ARMS86
Last Name: Arms
Exhaust manifold
Post by G.ARMS86 » Sat Nov 05, 2022 7:14 pm
Has anyone seen this happen before? Out driving today at it happened
G.ARMS86
Last Name: Arms
Re: Exhaust manifold
Post by G.ARMS86 » Sat Nov 05, 2022 7:17 pm
Post by TXGOAT2 » Sat Nov 05, 2022 7:58 pm
I've never seen anything like that. I've seen a lot of casting failures, but I've never seen such a neat one. The only thing I can think of, assuming that's not a modification made after manufacture, is that someone made a repair of some sort on a casting flaw, perhaps a plug pressed into a drilled-out blowhole.
Post by John kuehn » Sat Nov 05, 2022 8:02 pm
There must have been a plug or drill hole for an accessory. That hole is to neat for a blowout.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Nov 05, 2022 8:08 pm
T-ermites!
G.ARMS86
Last Name: Arms
Post by G.ARMS86 » Sat Nov 05, 2022 8:16 pm
[/quote as far as I remember there was nothing there and I'm leaning towards it was a casting repair that failed
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sat Nov 05, 2022 8:19 pm
Would it be for a spark plug to light off some gas and make flames out the pipe?
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Nov 05, 2022 8:22 pm
An OF manifold that was once plugged???
Post by Scott_Conger » Sat Nov 05, 2022 8:25 pm
prize goes to Richard...
Fire_chief
First Name: Charlie
Last Name: Gagel
Post by Fire_chief » Sat Nov 05, 2022 8:27 pm
Found out that it was for a hot air pipe for an accessory carburetor. The hole was plugged, but not correctly.
Post by John kuehn » Sat Nov 05, 2022 8:30 pm
Looks like the hole may be around 3/4” but that’s a guess. If you wanted to repair it instead of brazing it up you just might thread it and install plug or threaded bushing with a smaller plug. Others will have another method to fix it.
G.ARMS86
Last Name: Arms
Post by G.ARMS86 » Sat Nov 05, 2022 8:36 pm
Oh ok well that's interesting
Post by Norman Kling » Sat Nov 05, 2022 8:49 pm
I'd look for a better manifold. Last I knew they still made repros. I bought and installed one about 5 years ago.
Post by Jerry VanOoteghem » Sat Nov 05, 2022 10:29 pm
Weird. Can you thread with a pipe tap and put a plug in it? At least as a temporary fix?
Post by Mark Gregush » Sun Nov 06, 2022 1:39 am
Maybe sell that one and get one without the hole. There might be someone out there looking for that exhaust manifold to complete their Stromberg setup.
G.ARMS86
Last Name: Arms
Post by G.ARMS86 » Sun Nov 06, 2022 7:46 am
Would you be interested in buying it then
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Nov 06, 2022 9:49 am
Richard and Scott are correct. The manifold is one that either came with a Stromberg OF originally, or was modified to use with one. The hole is probably threaded, or should have been, for the valve that turned on or off, the heated gas to pre-heat the air to the intake manifold. The hold is in precisely the correct place for the valve. P.S. Original Poster, if you don't want that manifold, I'll trade you a perfectly straight original manifold for it, and I'll pay all the shipping on both.
Post by Scott_Conger » Sun Nov 06, 2022 11:59 am
a gentle correction to Terry...
there would be a drilled/tapped hole in the BACK of the manifold, with a stud coming out centrally, through the large hole in front. The whole mess would be secured with a wing nut on the stud...no threads in the large hole in the picture...
