Driveshaft
dacapt1948
First Name: Phil
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1926 tudor
Driveshaft
Post by dacapt1948 » Wed Nov 09, 2022 2:00 pm
Here's a silly question, is it possible to remove the driveshaft without removing the engine or rear end? I need to repair the 4th main engine bearing.
Thank you
John.Zibell
Last Name: Zibell
Re: Driveshaft
Post by John.Zibell » Wed Nov 09, 2022 2:07 pm
One or the other has to make room. Depending on year of the car, you could move the engine forward without removal. But you are now so close to puling the engine and doing that work on an engine stand. Probably less work to just remove the rear end and drive shaft.
1926 Tudor
Les Schubert
First Name: Les
Last Name: Schubert
Re: Driveshaft
Post by Les Schubert » Wed Nov 09, 2022 2:26 pm
Unfortunately if the 4th main is bad, it is highly probable that there are other problems in the engine. I would certainly look at the centre main. Also is the pan straight.
Transmission bushings.
Just my experience.
dacapt1948
First Name: Phil
Last Name: Terry
Re: Driveshaft
Post by dacapt1948 » Wed Nov 09, 2022 4:19 pm
Thank you all for the information
