Brass speedometer
Randall strickland
First Name: Randall
Last Name: Strickland
Brass speedometer
Post by Randall strickland » Sat Nov 12, 2022 8:55 pm
Installing speedometer on a Freinds speedster and the inside cable is about one inch to short, is there a way to shorten housing?
Randall strickland
First Name: Randall
Re: Brass speedometer
Post by Randall strickland » Sat Nov 12, 2022 8:59 pm
Calble not a chain
Randall strickland
First Name: Randall
Post by Randall strickland » Sat Nov 12, 2022 9:10 pm
Tried to post picture of cable but will not post
Post by speedytinc » Sat Nov 12, 2022 9:37 pm
The common SW steel housings ends are crimped on, so yes is possible to cut @ the edge of the crimped end, peel the outer cable out of the crimped end, force a rod into the end to uncrimp/expand & re crimp.
I wounld not do this unless the housing had damage near the end. (this issue did recently come up for me.)
Make a new longer cable or make an extended cable end.
Last Name: Patrick
Post by jiminbartow » Sat Nov 12, 2022 9:41 pm
Let Russ Furstow do it.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sat Nov 12, 2022 10:24 pm
You can always use the original chain links. To adjust the length, simply add or subtract a link.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Sun Nov 13, 2022 8:59 am
The speedometer pictured is a "high speed" speedometer. It takes a 1:1 drive and not a 2.5:1 drive. It appears that the road gear and the swivel drive will not run the speedometer accurately. The cable should be around 48" long, and the length of the outer housing can be shortened. I hope this helps, Russ Furstnow
