intake manifold
Topic author - Posts: 414
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
intake manifold
Dog leg - has what I think is a backwards seven, then a space, 512, a space, and what could be an A or an N cast into the side you don't see on the car. Anyone know what that all means?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
- First Name: Langs
- Last Name: OldCarParts
Re: intake manifold
The “backwards seven” is probably a”T”. The factory symbol number for the early intake manifold is 512. So the complete designation is T 512 for the early intake intake manifold.
The factory symbol number was a designation Ford used internally to keep track of parts and their production. The engineering drawing for the part shows the symbol number, usually in the lower left hand corner of the drawing. The company’s cost accounting system used factory symbol numbers to keep track of the cost of producing the part. Entire departments at Highland park were called by the factory symbol number of the part(s) produced in that department.
Respectfully Submitted,
Trent Boggess
Trent Boggess
- Last Name: Foye
Re: intake manifold
That's what I thought. Usually by the time I get stuff the numbers are gone.
Here's the video on that particular part: https://youtu.be/5THKk7XCtuE
