Wire Wheel Lug Nuts
BRENT in 10-uh-C
Topic author - Posts: 483
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Wire Wheel Lug Nuts
I am wanting to convert my '26 Depot Hack over to wire wheels. I have straightened & restored wheels, along with correct hubs ready to install however I do not have any lug nuts. Am I correct that reproduction original-style lug nuts are out of production? What are options??
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Wire Wheel Lug Nuts
If the vendors are out, options are: 1. find someone with new reproduction nuts who will part with them, OR 2. find some original or reproduction nuts that need replating and have them replated, I do not know if Model A nuts will work. Maybe you know, Brent. I do think that A and T are the same thread, although the taper or the shoulder against the wheel may be different. Of course, if they do work, they won't be correct, but they'll hold a wheel on a hub, until you can find correct ones. These are modern application nuts but check and see if they will work until you can get the right ones: Ebay listing 383102515260.
Professor Fate
- Last Name: S
I got a full set (20) from Lang's 7 months ago. Make sure you use the washer for each nut.
________________
**FATE**
**FATE**
- Last Name: Hatch
Brent : There is a trailer lug nut that looks a lot like T lug nuts.
Just be sure to get the solid ones.
Dan
Dan
The modern version in the ebay listing.ModelTWoods wrote: ↑Sun Dec 11, 2022 3:55 pmIf the vendors are out, options are: 1. find someone with new reproduction nuts who will part with them, OR 2. find some original or reproduction nuts that need replating and have them replated, I do not know if Model A nuts will work. Maybe you know, Brent. I do think that A and T are the same thread, although the taper or the shoulder against the wheel may be different. Of course, if they do work, they won't be correct, but they'll hold a wheel on a hub, until you can find correct ones. These are modern application nuts but check and see if they will work until you can get the right ones: Ebay listing 383102515260.
Yes these are the one's I run on my 27. The short version. I believe the hex size in the originals is a bit smaller. 11/16. these are 3/4 "
They look very close to the original ones.
When I built my speedster, I bought modern chrome plated nuts which were so close to originals you had to get down and read the numbers stamped in them to know they were not the real thing.
Some do have #'s stamped on them, some do not.
I run the un marked nuts. Yes, you cant tell them from original @ 5 feet.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Thanks guys, ...I'll just order some of the eBay ones and be done with it.
