1921 Center Door Inoperable Rear Windows
JBOYER95
First Name: Jon
Last Name: Boyer
* REQUIRED* Type and Year of Model Ts owned: 1921 CENTER DOOR - 1910 SPEEDSTER - 1946 CONTINENTAL CABRIOLET - 1958 CADILLAC 6039X
Post by JBOYER95 » Wed Dec 21, 2022 11:13 am
Hello,
Hopefully someone can best advise me what to do or what is wrong...
I have a 1922 Center Door and my rear-most windows do not roll down. The hardward is missing; the bottom window trim does not have a cutout for the strap, and the glass is fixed in position. Can anyone advise where to get the parts to make the rear windows operationsl?
Thanks,
Russ T Fender
First Name: Val
Last Name: Soupios
Re: 1921 Center Door Inoperable Rear Windows
Post by Russ T Fender » Wed Dec 21, 2022 5:48 pm
Don' t know where you can find what you need but this is what my original unrestored '22 Centerdoor looks like. The other windows have the latching track set up. The little gadget on the sill is an after market anti rattling device which works well.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Wed Dec 21, 2022 6:05 pm
The rear windows on a Centerdoor are lift strap operated regardless of year. The glass sits in a metal channel that has a lip that catches on another lip on the inside. You lift the glass and pull it gently towards the inside of the car and it slides down. There should be a window garnish inside with a slit in it to allow positioning of the strap.
William L Vanderburg
1922 Center Door Sedan
JBOYER95
First Name: Jon
Last Name: Boyer
Post by JBOYER95 » Thu Dec 22, 2022 4:36 pm
Here is what the window frame looks like. Almost as if someone decided to modify the windows so they would be fixed glass versus functional.
