Choke rod on Holly NH carburetor
Topic author - Posts: 15
- First Name: Noel
- Last Name: O'Keeffe
- * REQUIRED* Type and Year of Model Ts owned: 1927 2 seater soft top
Hi Folks,
Can anybody tell me how I could stop the Choke Rod from vibrating clockwise or anti clockwise thereby changing the mixture on my 1927 Model T
Holley NH Carburettor 6200REBB item number from Langs catalogue
Re: Choke rod on Holly NH carburetor
Where the swivel is connected to the top of the carburetor, there is a double edge crimp which fits the top of the jet where the needle valve enters the carburetor. Pinch those two sides closer together and it will hold the rod in place.
As Norm posted. Crimp the split collar around the barrel to get more resistance to prevent adjustment backing off.
- First Name: Noel
Thanks to Norm & Dan for the very quick response. Would I be correct in thinking its the black "U" clamp that moves over the brass part of the jet. I'll try that tomorrow.
Happy Christmas, from Ireland, to you both & your families and best wishes for 2023.
Noel
Noel
Yes. You need to remove the needle & squeeze those 2 tabs together a little.
- First Name: Noel
Thanks speedytinc
Noel
Noel
- First Name: Roy
- Last Name: Stone
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring--1925 Tudor
I also put a rubber grommet in the dash.
