Choke rod on Holly NH carburetor
corkmodelt
First Name: Noel
Last Name: O'Keeffe
* REQUIRED* Type and Year of Model Ts owned: 1927 2 seater soft top
Post by corkmodelt » Fri Dec 23, 2022 4:52 pm
Hi Folks,
Can anybody tell me how I could stop the Choke Rod from vibrating clockwise or anti clockwise thereby changing the mixture on my 1927 Model T
Holley NH Carburettor 6200REBB item number from Langs catalogue
Re: Choke rod on Holly NH carburetor
Post by Norman Kling » Fri Dec 23, 2022 4:56 pm
Where the swivel is connected to the top of the carburetor, there is a double edge crimp which fits the top of the jet where the needle valve enters the carburetor. Pinch those two sides closer together and it will hold the rod in place.
Post by DanTreace » Fri Dec 23, 2022 5:06 pm
As Norm posted. Crimp the split collar around the barrel to get more resistance to prevent adjustment backing off.
corkmodelt
First Name: Noel
Last Name: O'Keeffe
Post by corkmodelt » Fri Dec 23, 2022 5:27 pm
Thanks to Norm & Dan for the very quick response. Would I be correct in thinking its the black "U" clamp that moves over the brass part of the jet. I'll try that tomorrow.
Happy Christmas, from Ireland, to you both & your families and best wishes for 2023.
Noel
First Name: john
Last Name: karvaly
Post by speedytinc » Fri Dec 23, 2022 5:30 pm
Yes. You need to remove the needle & squeeze those 2 tabs together a little.
corkmodelt
First Name: Noel
Last Name: O'Keeffe
Post by corkmodelt » Fri Dec 23, 2022 5:39 pm
Thanks speedytinc
Noel
rofirestone
First Name: Roy
Last Name: Stone
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring--1925 Tudor
Post by rofirestone » Fri Dec 23, 2022 10:50 pm
I also put a rubber grommet in the dash.
