Has anyone powder coated their running boards?
Spade
Topic author - Posts: 25
- First Name: Curtis
- Last Name: Fesler
- * REQUIRED* Type and Year of Model Ts owned: 1923 Fordor
I attended a car show this weekend. My car, a 1923, Fordor, Black is not show quality but is a great driver. I drove it the 32 miles to and from the show without any problems. The biggest wear issue on the car is the paint on the running boards. It wears off and shows signs or rust. I pulled them off last night and I'm considering taking them to powder coating. I want kids and people to be able to climb on the boards and view the interior of the car without concern for wear. Is this a viable option?
- Last Name: Strange
Re: Has anyone powder coated their running boards?
I had mine powdercoated, they look great and match the rest of the paint perfectly. I have an aluminum step plate and am careful to use it, so I can't comment on whether the powder coat will hold up to wear better than paint or not.
Nunsio1
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
I have used POR -15, very good product, brush on, or spray on, bulletproof, flexible, etc- used by auto restoration pro’s.Web site very informative
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
Rust Bullet has held up very well for me.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Would believe powder coat will be good, the ‘27 has acrylic enamel paint, going on 14 years now, only the tops of the diamonds in just where the foot steps is missing, not enough to distract from my driver
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
I had the running boards on my white speedster powder coated in 1995 and the tops of the diamonds
are starting to show some wear now. This car has seen lots of use since I built it.
If the running boards were black I am not sure you would even see this wear.
In my mind the only way to go. About half the metal on the speedster is powder coated and has held up well.
Harry
Harry
EricMac
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, '92 Stynoski, 'owner emeritus
I had mine done in 2006 and have used the car quite a bit since. It's time to do them again now.
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor (2)
1927 Touring
1927 Fordor (2)
1927 Touring
MWalker
- First Name: Mike
- Last Name: Walker
That's a good place for powder coating.
