I have a HEAD ache
26Tpickup
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 1914 Speedster, 1915 Touring, 1920 Center Door, 1926 Roadster Pickup, 1926 Tudor
I have a HEAD ache
Post by 26Tpickup » Fri Jan 13, 2023 3:43 pm
Ok, I moved from Texas to Ohio and wasn't prepared for the cold winter storm...yes, my head cracked. Many of the purest may have noticed, I swapped a 1926 engine into my 1916. Forgive me, I'm old (not wise) and prefer to use a starter. However, I still have the original 16 motor.
So, here's my question, Can I use the 16 head on the 26 block? And then explore if there's other damage.
The more I know, the more I know I don't know... :roll:
Re: I have a HEAD ache
Post by RajoRacer » Fri Jan 13, 2023 3:49 pm
Ouch !!!! Hopefully the head let go before causing "block" issues. Low head can replace a high head - only the water outlet is different.
Post by Norman Kling » Fri Jan 13, 2023 4:15 pm
You can do that, but be sure you use the proper coolant for your climate.
26Tpickup
Last Name: King
Post by 26Tpickup » Fri Jan 13, 2023 4:28 pm
Thanks Guys, Lesson learnt...
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Jan 13, 2023 4:35 pm
I would be really surprised if that is the only damage!
First check out the radiator. Any water still left in it?
Drain the oil and see if there is water down there.
Post by TXGOAT2 » Fri Jan 13, 2023 4:37 pm
..... danged waterpump blowed out the cylinder head!
Post by Scott_Conger » Fri Jan 13, 2023 5:03 pm
Water is only an acceptable coolant if one wishes to make Model T engines scarcer. So many blocks/heads have been lost to rust when there is absolutely no reason, since coolant has been available for decades that all but eliminate rust in water jackets.
As others have said, I hope a head is all you lost but am not holding my breath.
Last Name: House
Post by George House » Fri Jan 13, 2023 5:33 pm
And when you replace the cracked high head with the ‘16 low head you’re supposed to get 2 more horsepower but you’ll also need to replace the head bolts with the earlier shorter variety. Might as well run a tap on those threads and blow out the holes.....Then come home to Texas 😎
Post by Jerry VanOoteghem » Fri Jan 13, 2023 6:46 pm
Have a look at the bottom of your lower radiator tank to see if it's bulged. A sign that it got frozen too.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Jan 13, 2023 7:47 pm
Jerry, several posters have given you some good advice so far I’ll attempt to add to it.
1-Use the bolts that you will remove from the low head on your 1916 engine
2- if you have domed pistons in the engine with the cracked head (by the way an easy repair) you will need to see if you have clearance in the combustion chamber of the low head
3- you may be able to reuse the head gasket that is on the engine that has the cracked head
Hope it helps, good luck! Best John
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Jan 13, 2023 10:21 pm
if you are in Ohio, I have some heads on the shelf.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Fri Jan 13, 2023 10:44 pm
Check the front and sides of the block real close. JB weld can fix a lot since it has no pressure on any of it.
