Home made simple tool that works!
vech
First Name: Craig
Last Name: Vechorik
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1922 coupe
Post by vech » Tue Jan 24, 2023 9:09 am
If you are installing a hogshead, all by yourself, trying to hold onto it, and get the high gear brass "fork" into the slot, while maneuvering the hogshead while the gasket goo is drying before you can get it in position, can be a frustrating job. I was standing there, looking at the when I had an epiphany as to how to make a simple tool to keep the fork under control without any manipulation.
I cut this out of a piece of scrap neoprene rubber, using a gasket punch and a box cutter. It pops on the high gear shaft between the two arms, and keeps the fork more or less in the correct position. Since the rubber is flexible, it has give, and allows the fork to move into the slot with ease. After the hogshead is in place, you simply pull it out. Of the many times I have installed a hogshead, and struggled, using this simple tool, made the installation a LOT easier. I thought I would share this with everyone, it's easy to make and WORKS!
"If a fly can, a flywheel" :shock:
MWalker
Last Name: Walker
Re: Home made simple tool that works!
Post by MWalker » Tue Jan 24, 2023 9:37 am
Good idea! And easy to remove when it's all together.
Last Name: Wrenn
Post by TWrenn » Tue Jan 24, 2023 9:39 am
Well, like they say... " a better mousetrap"! :lol:
I used to just use zip ties, but by golly this looks simpler, think I would drill a small hole in the top edge of it and attach a string to it, just in case klutzy me would drop the dang thing into the "oil drink" pulling it out. If there's a way to do it, believe me, I'll find it! :lol:
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Tue Jan 24, 2023 10:14 am
Great idea, Vech!
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Tue Jan 24, 2023 10:42 am
Great idea, thanks for sharing.
Post by RajoRacer » Tue Jan 24, 2023 11:29 am
Well Done Sir !
Post by Norman Kling » Tue Jan 24, 2023 4:14 pm
Looks like a good idea.
Post by Jerry VanOoteghem » Tue Jan 24, 2023 4:26 pm
Cool! I like it!
Last Name: House
Post by George House » Tue Jan 24, 2023 4:55 pm
Yeah 👍Great idea Craig. Thanks for sharing 🙏
