Hempey cooper boring bar
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Wed Jan 25, 2023 1:50 pm
I picked this up a couple years ago and am just getting around to mess around with it now, someone has taken false cams off it and the boring bar has to be removed to install them back on, has anyone ever taken boring bar out?thanks
Last Name: Hatch
Re: Hempey cooper boring bar
Post by Dan Hatch » Wed Jan 25, 2023 2:18 pm
Been long time since I used one, here is a wag.
Run bar as far as you can one way and unbolt the cap on end of frame, remove that bushing and fit fake cam. Reinstall bushing , run bar as far as possible other direction and repeat.
Good luck Dan
Randall strickland
First Name: Randall
Post by Randall strickland » Wed Jan 25, 2023 3:09 pm
Dan
I tried but the bar has a key slot and it stops before it clears the bushings
Last Name: Hatch
Post by Dan Hatch » Wed Jan 25, 2023 3:17 pm
Well I said it was a wag not a swag. I don’t have a car Hempy anymore, but have a Fordson. I will try and drag in out tomorrow and look. Should be the same. Dan
Randall strickland
First Name: Randall
Post by Randall strickland » Wed Jan 25, 2023 5:59 pm
Got it apart
thanks
Randall strickland
First Name: Randall
Post by Randall strickland » Wed Jan 25, 2023 6:04 pm
Dan I will take some photos and post when I get a little time
Last Name: Hatch
Post by Dan Hatch » Wed Jan 25, 2023 9:35 pm
That will be good. That way next guy will know how to do it.
I used one for a long time. I put a sprocket on mine and modified an old Linde wire feeder to power it. That cranking gets old fast. I put a reversing switch on the drive so I could run it in or out. Worked like a champ. Good luck with it. Dan
Randall strickland
First Name: Randall
Post by Randall strickland » Sun Jan 29, 2023 8:50 pm
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Wed Feb 04, 2026 3:29 pm
Randall do you still have this hempy? Id love to get measurements from the cam blanks mine are missing
